Thread: Radiator question
Showing results 1 to 5 of 5
    Radiator question
    Hey. Anybody know the difficulty level of replacing a radiator and radiator bottom and top mounts on an 04 GTS? any input appreciated , thanks
    easy as pie bolts come off brackets remove remove radiator after unplugging fans and then remove fans from radiator then replace fan parts and re install hoses of course
    Thanks. I did see a post /tutorial about radiator replacement, I thimble was on. 8g. Is it the saMe set up? Any special tools needed?
    Just a 10mm, 12mm socket, needle nose pliers, flat head screwdriver for hose clamps (if applicable), a drip pan for coolant and a medium cup for auto tranny fluid
    Do you know if the 04 GTS, 6cyl 3.8 comes with the radiator with transmission and engine oil cooler. Looking for an aftermarket replacement. dont want to get the wrong one. how do you know if it has that trans and engine cooler?
