Thread: General Question Thread.
Showing results 21 to 40 of 52
    08-13-2008
    Waterbury, CT
    3,331
    trans model is F4A23
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    When people use the term "2G" what exactly they talking about? Not a 2G Galant.... right? Right now I'm under the impression that they're talking about the 2G Eclipse, 1995-99 because I read that you can buy 2G Eclipse parts that will work on a 7G Galant, IE: Short throw shifters. If so, are all 2G Eclipse parts interchangable with our 7Gs? I've found that it can be pretty hard finding performance parts for 7G Galants.
    Oh and another question while I'm posting. Has anyone heard of PDK Von Max wheels? I found some that I like and they're in my price range, they come with a lifetime structural warranty so they sound pretty reliable. Anyone had experience with this manufacturer?
    08-13-2008
    Waterbury, CT
    3,331
    yes 2g eclipse. most parts are interchangeable.
    2014 Lancer Evo GSR
    06-16-2010
    Fort Mill, SC
    2,282
    Quote Originally Posted by Corey2kG View Post
    Want some deep in my exhaust thinking Magnaflow. Any suggestions?
    Hey uh Corey, I started an 8G thread like this... Fail...
    Sent from my iPod touch using Tapatalk 'cause I'm awesome
    -Andrew
    where i can buy the inder fender plastics? i dont know how are named xD
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    Iner fender liner is what I call them. These are the plastic parts that are screwed to the inside of the fender, not to be confused with the plastic spray shields bolted to the frame and hanging above the axles on each side of the motor to keep road debri and spray off the engine/fan belts.
    I'd hit a junkyard as I am sure they'd be cheap. There are not many folks looking for them.
    I am sure I have them from a 1995 S I parted out if you have no luck locally. If you can't find them, PM me;
    1) your address so I can calculate shipping
    2) tell me what exactly you want (inner fender liner for driver's front, etc)
    I'll send you a picture of the part so you can see the condition and confirm it is what you want. If it is what you want I'll get you a price for them shipped. Again, the junkyard will probably be your cheapest source for these.
    jjj
    am, i need the rh and Lh, complete, the problem is that im mexico isnt too many galant's at the yunkyard, how much can u sell me it shipped to san isydro california? there lives a friend,
    __________________
    12-18-2008
    Central Kentucky
    805
    Can anyone that has found the foglight wires give me some tips on where to find them? Would it be closer to the headlight switch? And where in the front? Thanks.
    Also in case I can't find them how do u wire them with the stock switch?
    amm. if your galant are ES, need to have the wires stock, in the S ones, dont have.
    __________________
    12-18-2008
    Central Kentucky
    805
    Ya its an ES. I looked for a little but the other day but didn't see them. Just wandering if anyone may know where they are hiding.
    08-13-2008
    Waterbury, CT
    3,331
    In my s all the wiring was there. For the switch it's behind the panel where the dimmer switch is. The connectors for the lights themselves will be tucked in the wiring harness down around the sides of the radiator
    2014 Lancer Evo GSR
    12-18-2008
    Central Kentucky
    805
    Ok thanks man. Going to do some searching tomorrow.
    08-13-2008
    Waterbury, CT
    3,331
    all of our cars are pre wired. the fog switch is behind the dead switch and the power mirrors is behind the big square piece. the fog connectors will be easy to find too
    2014 Lancer Evo GSR
    12-18-2008
    Central Kentucky
    805
    Well I can't find the fog light plugs wot wires for them. Does anyone know how to wire the switch so that it is just a switch tuning off or tue headlight power?
    Here is a pic of the switch.
    12-18-2008
    Central Kentucky
    805
    If I take my center caps off my wheels will it hurt anything? Someone to of me it would be bad for the wheel bearings but I don't see how it would affect them at all.
    03-12-2007
    Dallas TEXAS
    2,041
    Quote Originally Posted by 98mgalant View Post
    Nope
    Sent from my android using tapatalk
    I have been away from this swap for too long. I have an extra spacer and cant remember where it came from. Its a 63t motor I had the whole thing on the bench engine trans and transfer. Replaced oil pump, timing components, rod and mains. Where does this go?
    Thats from the front balance shaft sprocket. Id assume you have the plug there so you dont need it.
  19. #39
    Thanks, trash can time and sigh of relief!
  20. #40
    12-18-2008
    Central Kentucky
    805
    So it seems that I post in this thread more than anyone else.lol
    Here's my next question. I know that you probably can't say for sure but about how low should I be able to go without having issues with the front upper controll hiring when I hit big bumps? I have d2s and try are pretty stiff but sometimes when I hit big bumps it sounds like something is hitting really hard.
