Thread: All wheel drive
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 45
    All wheel drive
    You want mods for the 9G? Here's a good one...
    A conversion to all wheel drive for the DB/FWD platform.
    A lot of previous mitsi model bits just bolt in, or bolt in with light machining.
    I posted this before, but in the wrong place so here it is again.
    The transfer unit clears the tunnel to the right side of tunnel...giving room for an exhaust alongside....bloody awesome!....lol
    Still almost too good to be true so far....
    It's all in there except for one little important shiny thing...lol.......the steering rack.....
    Still gotta fabricate some 100mm standoffs to mount the rack...
    Was thinking of steel tubes with a dual triangular lean section all welded to the x-member should do the trick..
    That...will be an engineering job cause i don't have a clue if the steering geometry would be affected.
    Start with this perfectly good cross member.......Give it a wash with petrol and wire brush else you'll be cursing all the grease...
    Cut this much out...carefully...
    Don't cut any of the back section for minimal torsional integrity compromise.
    then wack it all back on the car for the seventh test fit....
    Looks like a bum in a bucket after a little bit here and there...
    rear view final...note no rear metal removal in this err...."advanced" re-design...lol
    Got the brother ex Tonsley round for a few beers and here are a few suggestions..
    Steering rack needs to be in this position...
    Make a dual box frame and weld it under the crossmember to firm it up.
    overall clearance reduction about 50mm
    another view
    add plenty of beer and it will all be good...lol
    We pulled apart the AWD hubs from the AWD and compared to the 380 rears and surprise surprise surprise.
    They are interchangeable! All I have to do is get some basic machining done, relocate the ABS sensor ring and fabricate an adapter to bolt the rear diff in and presto! She'll pop the driveshafts straight in with a hole through the hub...
    No suspension or chassis modifications , no brake work needed....even handbrake stays stock.
    The 10mm shorter track will be taken up by driveshaft splines....
    It's too good to be true....so many potential headaches averted..!
    See attached pics...the AWD hub is almost a perfect fit (will just require a thin shim)
    The longer I plug at this little project the more I am convinced that Mitsi had planned an AWD 380 right from the floor pan design...
    These photos are of the drivers' side rear 380 wheel hub and the 380 hub next to each other on the 380 rear axle arm.
    Note no hole through hub for the driveshaft spline ...cause in a 380 it's not driven ...lol
    The AWD magna/Diamante uses the ABS sensor on the driveshafts whereas the 380 uses it on the HUB...
    hopefully it is just a press fit and will move to the AWD hub without any drama....maybe just some heat and a love tap.
    Today's effort...had to do some work to pay a couple of bills...
    Somethings missing.....lol
    There it is....only takes a handful of bolts, about 15 minutes and the whole lot drops to the ground
    Do I see an obvious hole left for a future upgrade by Mitsubishi?
    What the hell...I can fit any damn diff I like into this thing, as long as the final drive is correct and the driveshaft lengths are good.
    Nah...easier to use the magna/diamante unit ...for now...lol
    Damn I wish I can do big project like this with my G.
    11-29-2009
    Chadds Ford, PA
    2,768
    wow very impressive i like it
    08-04-2003
    NY
    4,344
    Nice work man.
    99' Galant ES
    4G64/63T
    AEM EMS
    06-13-2008
    Bronx, NY
    2,606
    WOW big project. post videos when she runs.
    SOHC Turbo
    AWD install, then delete FWD. RWD Galant FTW!!
    +1=)
    I like this. When do you plan to be finished?
    Icon7
    Three engineering houses involved
    (a)
    -the front x-member/K frame is being welded up at the moment.
    -the rear axle is being drawn up then welded next month
    -the rear hubs are being drilled/splined after the axle is welded
    (b)
    -the tail shaft mounts get welded to the under body after that
    -the tail shaft gets cut/spliced/balanced April sometime...hopefully
    (c)
    The forged engine to power it all will be ready in two weeks...hopefully.
    that's in a best case outlook.
    what could possibly go...wrong?
    NEWBIE
    09-16-2009
    Hollywood, Florida
    36
    I think it would be a hell of a lot easier for us Americans to make this conversion work, all we have to do is use the Endeavor parts..... our only issue would be the tranny (the Endeavor uses an automatic) and the gearing, both in the tranny and rear diff, unless your making your 2.4 all wheel... then you can use the evo tranny and diff
    So I have a 06 2.4l auto. Will the evo tranny bolt up to this engine?
    Quote Originally Posted by boss102372 View Post
    Don't think so.
    I've never seen a 4G guy do it... And I don't think the 4G69 engine was ever jn the evo?
    So imma say no, unless you do lots of mods :)
    speechless
    04 GTS 9G
    FoR Sale:
    2004-2006 Fog Lights $50
    shoot me a pm
    updates?
    damn the 9g's gonna become awd before anyone finishes making the 8g awd.
    2002
    4g64 dohc turbo 5-speed
    gt30r @20psi stock block,mbc
    2.5" tbe
    evo 8 ecu and maf
    Quote Originally Posted by reiketsutsukigami View Post
    That is because the 9G shares the same chassis as the Mitsubishi Endeavor (which obviously is available 4wd). So, differing from the USDM 8G and JDM 8G NOT sharing the same chassis. The Endeavor is essentially an AWD 9G Galant, which, of course is available in the US.
    08-04-2003
    NY
    4,344
    Dont be so sure about that......
    99' Galant ES
    4G64/63T
    AEM EMS
    Nice work. +Rep for you!
    05-31-2005
    4,735
    get em stewi
