Neither fit. We have a 5x114.3 bolt pattern.
Search is your friend; use it.
https://www.thegalantcenter.org/showthread.php?t=34654
Hi, I would like to know if one of these rims or both would fit on my 2003 Galant ES. The specs of the rims are:
17"x8", 35 offset and 5x112 bolt pattern
17"x7", 38 offset and 5x100 bolt pattern
Thanks
-Andrew
no no no, offset/width/size/tire size all play a factor.
You can get an idea here: www.discounttiredirect.com
In general, a 17" diameter, 7-7.5" wide wheel around 42 offset will work unless you are after some really wide tires or have a big brake kit making the design a big factor too.
https://www.thegalantcenter.org/showthread.php?t=18010
This should cover things well for you.
Thanks to all of you!
No problem!!
Sorry Dave. I forgot you wrote that up even though I just read it. Jeeze.
Sent from my iPod touch using Tapatalk 'cause I'm awesome
-Andrew
