On the old RPW webb site, they said that running a supercharger causes higher temps., and that most tuners just run a richer mix to lower temps.
( I can't find the quote on the new site or I would post the eaxct quote)
How does that affect the engine in the long and short run.
If you add an I/C to a supercharger would that keep oil on the proper temp range?
As far as "lag" if you do nothing to an engine but bolt on a T/C or a S/C why would there be any lag? The engine would just run as it did prior to adding either of those.
Also a supercharger, unless it is a roots type, would probably need some RPM build up before really kicking in also ..no?
And last, if I don't want to change the piston heads I probaly can't go over say 8PSI max, so which setup, a TC or a S/C with the right exhaust, would be a better set up for regular stop light to stop light and daily driving?
