post the codes, but it could be a wiring flaw. Make sure you havent swapped grounds for the signal and heater. These are different. You want to monitor the voltage at the signal wire. With the car warmed up it should be around 0.5 volts and constantly fluctuating
As for the clutch chatter, did you lube the surface of the TOB and the shaft?
