Thread: Repeated burned exhaust valves -94 GS
Showing results 1 to 20 of 26
    StockGS
    I've had this 94 DOHC GS since rolling out of the showroom in 93. Burned first exhaust valve @ about 120k. Now I get one about every 20 - 30k miles.
    Now have 250k miles
    Just burned another exhaust valve (4th time) random cylinders..
    I have used 2 different machine shops
    I have used Mitsu valves and aftermarket from one of the shops
    Never overheated
    Runs a little rich (a little smut at exhaust pipe)
    Using prem. fuel as required
    Being OBD I ....I haven't run codes yet. MIL comes on sometimes w/ city driving but resets off on the open road (OBD I inspection not required in my area)
    Could the EGR (maybe stuck open) cause extra heat / these valves to fail?
    Thanks for any help!!....I'm "burned-out" on this...
    08-13-2008
    Waterbury, CT
    3,331
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    StockGS
    Thanks for the link!.....yes, most everything I read on exhaust valve failure leads to the valve not cooling properly, or quality of the valve / seats.
    I've tried two different machine shops and two different sources for parts. Now I'm thinking about the possibility of a restricted exhaust system or maybe running a little bit cooler thermostat?
    anyways....thanks for the come-back...
    08-13-2008
    Waterbury, CT
    3,331
    upgrade to stainless valves if the problem persists, or it may be just worth it to do it now. check for a clogged cat as well.
    link to stainless valves
    http://cgi.ebay.com/ebaymotors/4G63-...item588c560ce2
    2014 Lancer Evo GSR
    StockGS
    sounds like a plan..... I've got the head off now .......definitely need to do something different this time...
    like your 96!....I wish mine was a 5 speed. the auto tran is "crazy" ......has been since it was new.
    08-13-2008
    Waterbury, CT
    3,331
    Quote Originally Posted by StockGS View Post
    id much rather have started with a GS, ive been looking for 1 for like 3 years with no luck
    i converted mine to 5 speed like many other members and its well worth it.
    2014 Lancer Evo GSR
    Is the engine loosing oil? I bet the oil rings are shot to have the valves burn so fast.
    Lower temp. thermostat will decrease the block temps, but will not do much for the head since it is oil cooled only. It is still a good idea to replace the thermostat with 180 deg one. It will regulate between 180 and 190 deg unlike the stock which is 190 deg.
    Clean the EGR, its a 20 min job
    Hmmm "oil cooled only."?
    Yeah, thanks. I had just woken up when i typed it.
    its fixed now
    StockGS
    it is loosing oil, and it shouldn't be from the valve stems.....i've put new stem seals every time. i just didn't relate worn rings to burned valves. thanks for the advise!
    i have cleaned the EGR, but not sure how to know if it working other than by substitution......and not sure in my case if it is stuck open or closed is more detrimental to the valves..
    Clean the EGR with seafoam or a thing called Chemitool B12 or some like that. I get that second one at Walmart for $3. Use an old toothbrush to reach inside the ports
    For the EGR to cause any fault it has to be stuck open. That means all the exhaust gasses routed thru it go to the intake manifold and into the combustion chamber. But it cant be that much anyway, so most likely the oil rings are shot.
    You can buy pistons and rings for like $100 off ebay and do the work yourself, its very easy. You dont even have to remove the engine, just pop the oil pan open and undo the rod bolts. You'll need basic tools like cylinder hone tool and piston ring compressor, you can find both at harbor freight for around $30. You'll need a tube of RTV to seal the oil pan, new HG, new rod bearings.
    Shoot your 90% there only another easy hour and the motor is out on a stand. The fuel system can be the issue as well get injectors cleaned and tested, fuel pressure checked and replace fuel filter and front O2 sensor. Was there something catastrophic at 120k like timing belt? Belt breakage seems to cause more harm to exhaust valves. It could be that minute damage was done at that point and it is just taking its time to really show. I would definitely get the head refreshed with every valve checked including seats, installed height and stem.
    StockGS
    ....with my 94 GS engine being 4G64 DOHC, am I using the same rings and valves as the 4G64 SOHC?
    is it the oil blow-by or weaker compression or both that affects the exhaust valve life?
    appreciate your advise on this....i hope i can return the favor to the group in the future..
    The rings are the same, valves are not. The DOHC head has bigger valves.
    Compression rings and oil rings are different. You can still have compression and burn oil cuz the oil rings are shot. That was my case before the rebuild - I had 190 across the board, but it was burning oil and all my exhaust valves were burnt on my SOHC head.
    StockGS
    no...never had anything catastrophic...( i was going to say it was always babied as a family car, but wife could have been giving it hell all along....the sob would move!)...at 120K, I was in the mtns. climbing a steep grade....i'm on the flats so now it happens when i'm punching the auto to pass...i had thought the valve was ready to chip and that just finished it off...
    even though i've used two shops and two sources for valves, i didn't know if the shops used specific valve / seat data on the DOHC ....i made a point to advise them
    If you got 250k out of the original auto you are doing something right and deserve a medal!
    StockGS
    yes...everything under the hood is pretty much original...except of course the E valves
    i will check the fuel components and as mentioned above...the cat may be restricted some.........yeah, it's orig....
    08-18-2004
    Charlotte, NC
    1,029
    i would replace the cat...something i need to do to my GS.
    1994 GS FYI
    DSM/CSM Manuals
    StockGS
    thanks.... never seen so much info on the GS.....i've been used to the exact opposite..
    08-18-2004
    Charlotte, NC
    1,029
    welcome to the GS Club...lol. never had burned valves on my GS but I can tell my cat is failing...its OEM but the car has been sitting for years. it got to go.
    1994 GS FYI
    DSM/CSM Manuals
