Thread: Galantman03's 8G Build
Page 8 of 70 FirstFirst ... 4567891011121858 ... LastLast
Showing results 141 to 160 of 1392
  1. #141
    This weekend I did a little fiberglassing. Just waiting for the other two gauges
  2. #142
    07-12-2007
    SoCal
    4,632
    Looks good, nice work!
    JDM Zenki Conversion
  3. #143
    08-04-2003
    NY
    4,344
    Nice
    99' Galant ES
    4G64/63T
    AEM EMS
  4. #144
    06-13-2008
    Bronx, NY
    2,606
    Very nice
    SOHC Turbo
  5. #145
    Thanks guys, I think I'm going to wrap it in the DiNoc stuff... Hey gotta question, for the oil feed line, if you put a t off of the oil pressure sender, is it enough volume of oil for the turbo itself? Just wanna make sure
  6. #146
    08-04-2003
    NY
    4,344
    I would feed it from a sandwich adaptor or by using an EVO filter housing and feeding from the filter housing.
    99' Galant ES
    4G64/63T
    AEM EMS
  7. #147
    sandwich adapter meaning you drop the oil pan and bolt an adapter to that and run almost like an oem turbo feed?
  8. #148
    08-04-2003
    NY
    4,344
    Quote Originally Posted by kylecanthurdle View Post
    No.
    Sandwich adaptor is a ring that mounts between the oil filter and filter housing that will have a few ports for which to source pressurized oil. You can use the ports for oil pressure sensors or for turbo feed lines. No need to remove the pan.
    something like this...
    http://cgi.ebay.com/ebaymotors/Gredd...s#ht_500wt_956
    99' Galant ES
    4G64/63T
    AEM EMS
  9. #149
    OK I was thinking about going that route anyways, I just need to find the fittings, but I still gotta drop the oil pan to install the drain tube, might replace it with a new one. Also Ive been searching around on here for the wiring on the 74 TB for the IAC, I cannot find it anywhere on here, but I think I'm over looking stuff, any ideas?
  10. #150
    does anybody have a pinout for the galant? I looked around here, found a link in G Torque's thread but its dead...
    Hey just to make sure I get the right tb gasket for the 74 to outlander manifold, will every hole line up?
  11. #151
    05-01-2008
    Manitoba
    1,589
    Very nice progress! Keep it up! Car's looking good!
    Tuned 2013 Evolution X GSR PB
  12. #152
    08-04-2003
    NY
    4,344
    I posted up the automatic ECU to 5-speed EVO ECU conversion chart in his thread, its gone? Im not sure if the 02 is different pinout, the one I posted was from a 00' from Napalm on C3g.
    99' Galant ES
    4G64/63T
    AEM EMS
  13. #153
    Quote Originally Posted by Galante View Post
    Thanks man its slowly going, so sad its going to be put on hold for 8ish months though...
    Nope I have that one Stewi, I'm looking for the Galant pinout, like pin 1 is where on what connector... QNZ had one, thats the link thats dead
  14. #154
    08-04-2003
    NY
    4,344
    I know I posted that up already too. Not sure which thread it was in, I know it was a project thread though....
    99' Galant ES
    4G64/63T
    AEM EMS
  15. #155
    08-04-2003
    NY
    4,344
    bang!!!!
    Couldn't find mine, but I found the one Aaron posted...
    99' Galant ES
    4G64/63T
    AEM EMS
  16. #156
    sweet! now as the evo ecu pin out is, this is read from the ecu correct?
  17. #157
    08-04-2003
    NY
    4,344
    yeah this is if you were staring into the end of the ECU.
    99' Galant ES
    4G64/63T
    AEM EMS
  18. #158
    Yeah.. Idk why I asked that... but I got it finished.. done for the night, but I'm going to meter everything make sure there is no shorts, and to make sure the pins are connected to the correct corresponding pin haha
    Also got me gauges and my 4 inch to 3 inch silicone reducer haha... so now I can use the spectra maf adapter.
  19. #159
    Finally... looky looky what came in today :) for those who have done the swap with a 74 TB, how did you wire it up?
  20. #160
    anybody know the part number for a 6g74 TB gasket? I cannot find it on here at all
Tags for this Thread
