Thread: Will it Fit: Alpine Center Panel Speaker
Showing results 1 to 4 of 4
    Icon2 Will it Fit: Alpine Center Panel Speaker
    Does anyone know if this will fit:
    Tech Specs:
    single-DIN car center channel speaker
    contains two 1-5/8" x 2" oval midbass drivers and a 1" soft-dome tweeter
    removable grille
    power range: 2-50 watts RMS (150 watts peak power)
    frequency response: 150-30,000 Hz
    sensitivity: 85 dB
    7-1/4"W x 1-15/16"H x 4-9/16"D
    "Triangle Circle Triangle Square"
    If you mean in the pocket below the a/c controls, don't see why not.
    Make sure to wire that correctly for nice even sound.
    If its a din size, yes it will fit, though Idk how you mount those
    Yes, but that is rather low to be mounting a center channel in any vehicle.
