The glove box?
If that's the case, just open it and push it inwards from the two sides and the two tabs(on the sides) should pop out. After that let it open all the way and slide it out from the bottom tabs.
Anyone KNow how to remove this??
I can't seem to figure it out..
IMMORTALIZED CUSTOMS
Sid Mundo Production
The glove box?
okay will try when i get home... thought there was a bolt on / screw
i thought there were himges on the bottom?
They are hinges, but they just slide off, no screws.
You know what? I was thinking of the screws on the door itself. I recently put my glove box on a weight loss program by removing that piece of tin from inside of it...
Got her out.. vry easy to do actually. i suppose i didn't want to forcefully do it and accidentally break it.
i actually have a problem similar to that, where the handle came off and now i can't open it... can someone help me figure out how to open it with out the handle?
"Triangle Circle Triangle Square"
you gotta strip it appart carefully.. it might take a while.. took me an hour to fix my handle.. =/
or you can find the tiny switch that the handle is connected to to poke/twist (can't remember which) that makes it pop open, where you then can unscrew handle/latch from the inside to disassemble it.
