Thread: Power Problem
Showing results 1 to 9 of 9
    WyteFang
    Power Problem
    at times my 9g will turn on but sometimes it will do the whole battery dead thing the battery is new and the alt. so what could it be?
    welcome.do you have an aftermarket radio,or any kind of system in your car?
    starter, loose battery cables, dead cell in the battery, ignition switch and welcome aboard.
    Your signature is against the rules too - Prophet
    WyteFang
    yea i have an aftermarket radio
    oh i forgot loose shifter cable can do it to.
    did you put the radio in or did someone else?
    WyteFang
    I put it in and im not so much a gear head i mean i can change a tire instale lighting crap like that, that is all lol
    if you put it in, and the problems started after the radio, make sure you didnt get the acc wire and the power constant wire mixed up
    04 GTS 9G
    FoR Sale:
    2004-2006 Fog Lights $50
    shoot me a pm
    05-14-2010
    Coachella, CA
    5,954
    Quote Originally Posted by Its Reu View Post
    Added to this, check your dimmer/illumination wires on that harness.
