Thread: annoying grinding sound
Showing results 1 to 8 of 8
    i have 09 galant es and i have a very annoying grinding sound in the engine bay i dont know excatly where is it its kinda under intake monifold or lower,,the sound starts grinding around 1000-2000 rpm and it goes away its really annoying if i go 20mph-30 mph,,its maybe a loose bolt or nut i dont know i really need help,,thank you soooo much..
    note no warning light on
    8th and 9th gen galants
    05-31-2005
    4,735
    its a heat shield loose. they already took 2 heat shields out of my 9g and now there is another effing metal noise that sounds like another metal loose. effing design flaw..
    so the car need to lift to take it off??it is hard??so no big problem??
    Mine has the same problem. Dealer adjusted it a few days ago and its already making the sound again. Will they just remove it if I ask? What is the downside to not having the heatshield?
    05-31-2005
    4,735
    pass over a hay and your car starts a fire. dealer did both of mine so i have no idea where.
    Quote Originally Posted by 9G View Post
    did you pay for that??
    05-31-2005
    4,735
    nope.
    oh ok,,thank you
