Thread: Intake Systems
Showing results 1 to 2 of 2
    noneothathani
    Intake Systems
    Will any of the Eclipse intake systems fit the 7g?
    MitsuMan
    Yes,...
    you need to cut the pipe though if u are talking about a CAI system...member paulbunyan bought the CAI from procarparts.com for the 2g Eclipse non turbo and said that it worked with some vutting and fitting...your best bet is to go with the Civic pipe, it has simmilar bends but you will still have to cut some too, you can always just buy the parts like an exhaust pipe (mandrel bent) and make your own, plus its a hell of a lot cheaper....see my post under performance section on what u need to make a CAI
    lata
    dean
