Thread: Radio fail!
Showing results 1 to 4 of 4
    WyteFang
    Radio fail!
    so i was taking my aftermarket radio out to install my stock one in the process my Clock turned off, know the radio and the clock will not work i think its a blown fuse but my manuall is like in sasquaches butthole and i have no idea what iam doing with this 9g, i need assistance where is the fuse
    Member SirSaula's Avatar
    11-20-2010
    Dallas, Texas (Lubbock)
    286
    hmm not sure if i have time I'll check my owners manual.
    9th Generation Mitsubishi G
    TGC Texas Chapter
    Friends don't let friends drive stock. Ever
    Check the manual for radio fuse, amp fuse, aux pwr fuse, 12volt outlet fuse, acc fuse all of the listed above are common for clock and radio.
    Update:https://www.thegalantcenter.org/showthread.php?t=39351
    Download Chasis electrical has everything.
    This thread posted by Prophet, you'll be surprised how far a little search and homework will go, in this case very far.
    WyteFang
    i found it it was in a yellow casing in the engine bay thnx guys
