Thread: Door lock trim question?
Showing results 1 to 8 of 8
    Excuse my ineptness, But I was wondering for the trim on the doors surrounding the lock buttons *Don't know the proper name* do I have to remove the entire trim to access it or can I remove it without going through all that hassle? It's an 03.
    12-13-2010
    Brooklyn, Maryland
    4,643
    Yeah, you should be able to just remove the screw holding the piece in and slide it off the handle.
    -Greg
    Ahh I meant like the control panel with all the locks and stuff..
    12-13-2010
    Brooklyn, Maryland
    4,643
    Oh, sorry, thought you meant the handle trim. It's been a while since I had that panel off, but I think if it is possible, it's still easier to just take the whole panel off and get it that way. The panel comes off super easy, couple of minutes tops.
    -Greg
    Get a Phillips and unscrew your panel, then pop it out from behind the bottom rubber trim with a flat head. roll down your window it's easier to take the panel off that way. Once its off remove the wiring harness from your control, and unscrew the piece. Pretty sure that should be it, but I have a terrible memory.
    I expected the Rocky Mountains to be a little rockier than this.
    Quote Originally Posted by Stepsascend View Post
    x2 if my memory serves it is exactly that.
    yea thats it just dont break off those hard plastic pieces that hold the door panel in place
    Thanks everybody! I got it off with a bit of work, I was just worried about breaking anything I needed.
