and the exhaust is dripping water to
sup guys i own a 99 galant 2.0 4g63 v4 auto tranny
when the car is cold and i cranket up a white and blue sky smoke comes from the exhaust and when the car is warm it become fewer but when i rev it come back again whats the problem guys?
my buddy says its a head gasket problem but open up the engine is expensive :( what to do no money right know and i just got my license :)
it sounds like it might be the valve seals or the piston rings.do you smell burnt oil?
It is most likely your valve seals. Tell us more about when you see it. If you give it gas, does it keep coming out? Or does it only do it after idling for a little bit?
If it was the head gasket, there'd be white smoke.
Sent from my iPod touch using Tapatalk 'cause I'm awesome
-Andrew
yeah is sounds like valve seals or worn piston rings allowing oil to pass through and burning it out of the exhaust.when a car burns oil it is a blue color if it was the headgasket it would be white smoke not blue.but this is common for a high mileage engine.
Sounds like piston rings my friend.
-Andrew
Oil leak some wheres, allowing oil to be burnt.
The question is where though. And that can not be known without tearing down the engine.
^Exactly, but seeing as it is probably a constant leak leads me to believe it's the piston rings. Which sucks, cause you have to tear it down to get to them i believe. Valve seals are easier. I've had my valve seals go, and they caused a cylinder 2 misfire. Pulled the plug and it was covered in oil.
-Andrew
No problem... We're here to help bud
-Andrew
no problem.good luck with the car.
what do you recommand me to do with the engine i wanna mod it for daily use
like air intake and throttle body
camshaft with gear
but is it ok fo the gear is auto trans?
Yeah it should be fine. As long as you don't try to turbo it or anything the tranny will be fine. I have an intake and bigger throttle body on mine.
I'd recommend spending the money on fixing it before modifying it. Maintenance is VERY important.
-Andrew
i shouldi will try to take soke pics and keep you guys post it
i live in bahrain btw its in the middle east
i support you guys
Thanks man... Keep us updated
-Andrew
