Thread: Longevity no balance shafts
Showing results 1 to 20 of 29
    I have done a ton of reading and studying on the balance shaft delete idea. This is a short summary of my findings and others opinions with BSE. Some of this info came from right here on TGC, many other sites and of course my own motors.
    pros-
    frees up horsepower because of less rotating mass
    fewer moving parts = more reliability
    no chance the weak tiny belt can break and tangle in the main timing belt.
    cons-
    -more vibration feel to driver/passengers,doesnt affect internal balance of
    engine.
    -some say the rear stub puts to much stress on pump and pump wears
    prematurely.
    -no oil groove on some replacement stub shafts caused damage in short
    period of time.
    -to high of oil pressure because of blocked ports
    I have seen and read a few methods of accomplishing this, not saying I agree or disagree with any particular one but here they are.
    1.simply remove small belt.
    -problem with this is you still have a shaft with weights and no other to counteract it and you have shaft rotating at 2x the crank rpm.
    2.leave front shaft in place or remove shaft and turn bearings around.
    -if you are taking the cover off might as well send a few more minutes and take a few pounds off the motor and block those holes.
    3.remove rear and replace with stub shaft or turned down original.
    - I was planning on turning the stock shaft down on a lathe until I looked at the surface the shaft rotates on the pump, mine only has 100k on it. I was thinking it was the best way to go as it was supported by 2 bearings this way. Since the bearing contacts are on two different components the chances of getting a perfect alignment is slim I have since changed my mind and am putting a good quality mitsubishi stub shaft in as well as a new oil pump.
    Heres the wear on mine.
    I had no balance shafts for a solid 3 years with no problems. My old motor was pulled and was to be put into a Talon, but my friend never finished the project.
    If you have too high oil pressure with the BS removed, then just port your oil pressure relief:
    http://www.dsmpurity.com/forum/showt...ng-mini-how-to
    I would NOT use the 3rd party shafts that do not have the oil grooves. Use OEM, or don't do it at all.
    IMO, the only reason I would do this is to not have to worry about a balance shaft belt snapping and killing your timing belt. The hp gains are negligible.
    IMO, the only reason I would do this is to not have to worry about a balance shaft belt snapping and killing your timing belt. The hp gains are negligible.[/QUOTE]
    The picture kinda sucks what I am trying to show is the damage on the journal from being slightly cocked from the factory with relatively low miles. Luck or line bore(who's going to spend that kind of money) is the only way to make perfect alignment in my opinion so why take a chance?
    Its not about HP. Its about rotational weight; less weight = faster revving engine
    yeah. When I yanked my balance shafts it was immediately noticable how much lighter the revs were. the vibrations are only noticable at low idle, and right around 3k rpms. but away from those ranges you wouldn't even notice a difference in vibration.
    I used the OEM mirage stubby. As well as the oem mirage spacer(which replaces the balance shaft belt sprocket on the crank with a much smaller and lighter steel spacer.
    Its pretty wild how much weight I have off of my engine. 8lb flywheel, aluminum crank pulley, balance shaft deleted.
    I left my front shaft in since I did the removal at my old rental house in the winter on my back in the rain on a gravel driveway laying under a tarp lol. It wasn't planned, but when my old oil pump locked up while idling in my driveway(talk about good luck) I didn't have choice cause i wasn't going to tow the car 100 miles back to Louisville.
    The key is to use OEM part, OEM gaskets, and Permatex ultra grey for your oil pan. Get a new oil pan if you can afford one, odds are your's is bent or warped anyways. Get a new oil pump front case if you can afford one. This way the new stubby shaft will have a new journal to ride on, instead of the journal that is however many miles old from your original oil pump.
    Honestly, I think i have more vibrations from the Prothane motor mounts than from the balance shafts. Its a lot smoother in the summer when the prothanes soften up from the heat. In the winter... its a little rough. You do get used to it though. After a while you won't notice, and for the most part i've never had a passenger even comment on the matter.
    Here is a slightly better pic. The dark gray line at the bottom half of journal is where it wore in and kind of egged out the journal a bit. It seems as if it could be putting extra pressure on the gears, causing binding and extra wear on case. Possible contributor to DOHC's locked up pump? I know I am taking no more chances.
    much better!
    the pump i was reffering to was my original pump with original balance shafts. Anything could have caused it. It could have been bearing material that got past the strainer screen in the sump. I've been running no balance shafts for about 5 years now I think. Maybe more. As long as i can remember anyways.
    North Bay...NorCal
    2,552
    My engine was built without it and much like everyone else it revs faster. I personally dont have much vibration even at low idle. With the car running, you would never know its on until the fans kick on. I think my oil consumption is because of the increased pressure and I gotta figure out the porting but it is definatly good feeling knowing that piece of shit wont fail....I ruined two engines because of that bastard
    The other thing I noticed is guys are saying to take the back cover off the oil pump to install the stub shaft. There is no reason to do this if you simply remove the balance shaft cover/cap. I definitely will do the ultra gray pan seal. Last season I used what I thought to be a great gasket, torqued the pan bolts to spec but within just a couple of hours they all had loosened and oil was pouring out.
    Not sure if I understand. You can leave the front shaft in, but if you don't use the BS belt, you need to remove the rear balance shaft and use the stubby shaft. If you just take off the balance shaft belt and use the stock rear balance shaft, your engine is going to be out of balance and give more vibration then if you used the stubby.
    Or are you just talking about not needing to remove the oil pump cover to remove the old shaft? I can't remember if the shafts will come out with the cover on or not, its been awhile.
    06-16-2010
    Fort Mill, SC
    2,282
    I hate to be a complete n00b, but what exactly is the purpose of the delete and what gains are there?
    How?
    Sent from my iPod touch using Tapatalk 'cause I'm awesome
    -Andrew
    TGC Regular shortdogg2k05's Avatar
    11-10-2004
    H-town, TX (the bayou city)
    556
    Mainly piece of mind that the balance shaft belt will not break and f up your timing. If you are not pulling out the motor or changing the oil pump assembly I would leave it alone.
    Back from the dead!!!
    Quote Originally Posted by seth98esT View Post
    The large aluminum front cover does have to be removed but you do not have to remove the 4 bolts and screw and separate the pump body from the large front cover just to bolt a stubshaft to a gear.
    04-08-2010
    Springfield, Mass
    1,225
    Hold on a second so you guys are saying the balance shaft is not needed? Wtf I could've had my car running a long ass time ago if I new this lol. That shaft was always getting stuck and breaking the belt so my car would shut off. I could've just removed it and been ok?
    «Carlos»
    11-10-2004
    556
    Quote Originally Posted by 99galantES View Post
    Yep
    North Bay...NorCal
    2,552
    yup, but if your car turned off because of this little thing i'd check the engine well before putting it back on the road. Both times my belt snapped, it bent my valves and I lost compression in 3 cyls...its a bitch. But be on the safe side and check everything first just to be sure
    Quote Originally Posted by w/oarctic7g View Post
    I did the delete using this method. As soon as I can get some more funds, I'm going to buy that stub and remove the rear shaft because my car feels like a magnitude 5 earthquake every time I hit the gas with the current setup. All the interior panels rattle and vibrate annoyingly. Some interior panels are coming loose. I do not recommend this method to anyone else. It takes so much away from the ride quality.
    Does anyone know about engine longevity using this particular setup? Someone recently told me that driving it with it shaking like it is could cause the crankshaft to warp and ruin the engine...but I don't know if this person knew what he was talking about though.
    "Speed never killed anyone. Suddenly becoming stationary...that's what gets you." - Jeremy Clarkson
    1997 Galant ES with '94-95 style front end and '97 style rear
    04-08-2010
    Springfield, Mass
    1,225
    my car is running fine just in my other motor it would get stuck everything else was fine i drove it like that till i got home and it would turn off then i swapped my motor
    «Carlos»
    My last engine would vibrate like crazy too, and when I pulled the motor, I found that the balance shaft wasn't even aligned correctly... the motor spun a rod bearing. Good to know for next time that we can just remove the bs altogether.
    Quote Originally Posted by mygalantwasfree View Post
    REmoving one shaft and leaving the oil pump one there is not a method of deleting balance shafts. It's just half assing the thing. Its no different than broken balance shaft belt would do to the engine. YOu either get the stubby or cut and center the existing shaft and then weld the hole.
