Thread: manifold and tb!!
Showing results 1 to 11 of 11
    manifold and tb!!
    I have a 02 gallant gtz and I need to find out the exact year diamante that i can use to get the intake manifold from
    06-13-2008
    Bronx, NY
    2,606
    2000-2004 diamante.
    SOHC Turbo
    04-29-2009
    Holyoke,Massachusettes
    3,600
    What he said lol. N I have installed on my car.
    FreakyDeaky
    2kG 6g72/74 5 speed
    05-03-2007
    Socal/Central Coast
    3,803
    actually 97-04 should work
    whew. I was hoping somebody who actually knows from experience would answer :) Adrian you saved the day.
    Also, within the years posted by beam514, you will need them from a Diamante WITHOUT cruise control.
    04-02-2009
    Denver Colorado
    1,447
    Just food for thought, I am going to give you a list of manifolds you can swap to.
    3.8L MIVEC & Non-MIVEC 6g75(good for about 15whp gains)
    3.5L Hyundai XG350 & Eclipse GTS
    3.5L Diamante
    The Diamante manifold is a good design over stock obviously, but the XG350/GTS, or 6g75 manifold will give you some better results.
    www.blackheartmotors.net
    You mean traction control? My Diamante TB has cruise control.
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by gtx View Post
    I believe mine might have had the traction control.. It has two vacuum actuators. I only use(d) the one for cruise control though.
    haha wow. Major brain fart. That's the option I was thinking, with the big awkward throttle body. I should have known better since they all have CC. Thanks for correcting me, otherwise the OP would have been on an endless search :-P
    Tihoff88
    not to sound like a noob, but ive been looking for manifolds online, and do i just need the upper manifold, or both upper and lower?
    05-03-2007
    Socal/Central Coast
    3,803
    Upper manifold only, the lower manifold won't fit because of the difference in deck height between the 6G72 and 6G74.
