Thread: 5 speed swap time coming - suggestions
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 43
    Hello TGC
    I am finally getting around to finishing up my parts for the 5 speed. For those who have done it - What flywheel are you using? A few tuners around here say that lightweigh flywheels can play games with the knock sensor because they have had false readings in evos so im curious if anyone has had issues with em?
    I have ordered an act 2100 for my setup and im thinking of getting an oem flywheel.
    Also another question is what shifter cable bushings did you guys use? On ebay and speed sites they have the brass/aluminum ones for evos and 2g eclipse but im not sure what fits. Im not talking the bushings for the base but the ones that connect the cables to the tranny.
    Thanks for the assistance
    if you go stock flywheel i have one ill give u for the price of shipping. im using stock a stock flywheel without any issues as for shifter bushing idk someone should chime in though.
    2002
    4g64 dohc turbo 5-speed
    gt30r @20psi stock block,mbc
    2.5" tbe
    evo 8 ecu and maf
    06-16-2010
    Fort Mill, SC
    2,282
    I think there is a thread out there with a full parts list. If I find it, I'll post it.
    Sent from my iPod touch using Tapatalk 'cause I'm awesome
    -Andrew
    I'm using the fridanza aluminum fly wheel, no problems, just not really much of 1st gear lol revs way fast... but your turbo so it might might not help you
    Thanks for the help
    Reike is the flywheel new by any chance? Tks for offer
    06-13-2008
    Bronx, NY
    2,606
    Galants dont have knock sensor
    SOHC Turbo
    his does, he added it from the evo
    thanks for the link i know about the thread but there is no part number for the bushing unfortunately and it doesnt specify which model car it came off?? Maybe goosey can chime in i asked on that thread as well i believe.
    And yea i forgot to mention my setup i guess -- i have an evo 8 ecu with knock sensor and such..
    the model gs or rs, any 4 cylinder 3rd gen eclipse transmission will work.
    no its not a new flywheel lol but still free is free.
    2002
    2.5" tbe
    evo 8 ecu and maf
    i have not been able to find any bushings for the 3g only the 2g and evo 8+++
    Thanks reiketsutsukigami i am gonna order a new one i appreciate the offer though.. You are running 20psi on a gt30r with stock internals?? Thats where i want to be next you get any knock counts that high? 18 gives me around 6 sometimes but the car seems to like high boost. 20 gave me 15 counts or so but i never bothered to tune it that high..
    06-13-2008
    Bronx, NY
    2,606
    Ohh did not know. So he changed the ecu and added the knock sensor harness.
    SOHC Turbo
    08-15-2006
    Perth Amboy, NJ
    1,558
    I'm using stock flywheel and ACT 2100 clutch setup. Been good so far :)
    run1206's Rear Disc Tutorial
    u ever fix the speedo run1206??
    08-15-2006
    Perth Amboy, NJ
    1,558
    nope :(
    01galant01 and I tried the solenoid fix SPD_FRK suggested but that only threw more codes. I think the only way to get rid of the 5 CEL codes is to get the evo ecu in, which is what i plan on doing this month.
    what about the speedometer you still cant tell your speed though??
    08-15-2006
    Perth Amboy, NJ
    1,558
    edit: speedo works only when my fuel tank is under 3/4 full
    that fix i plan on doing this month as well, maybe next week
    08-08-2004
    Las Vegas
    2,099
    if you type in evo bushings on ebay a tons of options come up im using these ones that they work fine
    http://cgi.ebay.com/ebaymotors/EVO-8...ht_1166wt_1165
    08-04-2003
    NY
    4,344
    There is a difference between using a lighter flywheel and an aluminum flywheel. I had a fidanza flywheel when I was using the 3g tranny and it was LIGHT like 8 or 9lbs, the motor spun up really quick but also lost revs easily during slower shifts, It never played games with my knock sensor. With that being said, I now have an ACT XACT Streetlite flywheel thats chromoly and it weighs about 12 or 13lbs with my evo trans setup and I really like it. Chromoly is good too because its strong and you can re-surface the flywheel 2 times before you need to replace it. So essentially you will go thru 3 clutches before you need to replace the flywheel. Aluminum flywheels often have replaceable friction surfaces but they are like $100 each and sometimes are a PITA to swap out because the hardware gets stuck.
    99' Galant ES
    4G64/63T
    AEM EMS
