Thread: Car pulls slightly to left while driving
Showing results 1 to 16 of 16
    I just put in GR-2's in the front and back, Ultimax Slotted rotors and Hawk HPS all around. I bedded the Hawk's in. It still pulls to the left, but here's the thing, it's NOT when I'm braking, it's only when I'm driving. Could it be the suspension or a pad catching a rotor? It's not a big pull, just a slight one, but before the job is was centered and I could take my hands off the wheel and I wouldn't drive into a ditch. Like I said, its not much, but you can definitely feel it.
    Thanks for any help. I'm going to get a tire rotation tomorrow, don't know if it would help, but I'm due anyways.
    did you get an alignment after putting the gr2s in?
    I did not, but I thought that they were supposed to be an OE replacement, so I didn't think an alignment would be needed. I'll get one next week if the pull hasn't corrected by then. It didn't lower it or anything, I still need one?
    Quote Originally Posted by hedonism View Post
    whenever you put in shocks/struts of any kind you should get an alignment.does it pull when you let go of the wheel?
    Well yeah. At the centered position, the car goes slightly to the left, so I have to compensate and go to the right a bit. 80$ more for an alignment. As if the installation wasn't enough already. sigh.
    05-03-2007
    Socal/Central Coast
    3,803
    If you touch the main suspension components, you should get an alignment.
    If you can, try to get the lifetime alignment package. At Firestone it's only $150, and there's really no limit to how many times you go get it done. This is good if you plan on more modding in the future. If not.. well than that's your call.
    Eh, I'll just pay the 80$. No need for more alignments, hate this pos handmedown so no need to spend any more hard earned cash!
    05-02-2008
    Hacienda Heights, CA
    3,014
    i donno, i went to Firestone to ask about it. the manager was being a dick when i was just asking a simple question. he said they dont offer that for modified suspensions. it would void the transaction and they will refuse to do it. but maybe he was just an asshole and other places dont care.
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by E_Emerson88 View Post
    I'm pretty sure at my place they don't care.. I've already had the first one there and my suspension is very obviously modified lol (at least for a car tech)
    05-02-2008
    3,014
    might be different for me since i have coilovers. springs might be okay since they are non-adjustable
    05-03-2007
    Socal/Central Coast
    3,803
    yeah true that. I'll have to look over my contract later.
    you would hear some noise if one of your calipers were locked. Also, the rotor would be a little "redder" than your other rotors if you had a locked caliper.
    Try the tire rotation first, since its free to do. This may resolve your issue. My summer wheels pulled slightly to the left, but when I put on my winter wheels, it corrected itself.
    You're going to need an alignment. Any time you put new struts/shocks/springs/etc on the car, an alignment will be needed. Repair shops love it too, because they know it needs to be done. It's one of the few things they tend to be honest about you needing after work being done.
    Allright thanks guys. I'll get an alignment tomorrow. Dammit, if I knew it was going to need an alignment anyways I would have gotten Koni Yellow's and lowering springs. Oh well, we can only learn from it right?
    Mmm. The hole in my pocket is getting bigger.
    03-12-2007
    Dallas TEXAS
    2,041
    aw man i got a easy fix for ya
    just pull more to the right LOL j/k
    alignment time!
    I guess it was well worth it.
    Front Left
    Actual: 0.02 Toe
    Before: 0.67 Toe
    Front Right
    Actual: 0.02 Toe
    Before: 0.69 Toe
    Total: 0.04 Actual, 1.36 Before
    Rear Left
    Actual: 0.13 Toe
    Before: 0.28 Toe
    Rear Right
    OK
    Apparently my left caster sits higher than my right so idk how the how it veered left. Whatever, fixed now.
