View Poll Results: spark plugs
Voters
8. You may not vote on this poll
  • platinum (NGK)
    1 12.50%
  • iridium (NGK)
    2 25.00%
  • copper (NGK)
    3 37.50%
  • v-power oem (NGK)
    1 12.50%
  • Other
    1 12.50%
Thread: Spark plugs
Showing results 1 to 6 of 6
    NEWBIE Acidrain620's Avatar
    02-20-2011
    where ever the navy puts me!
    33
    Spark plugs
    i have read that people on here stay away from platnium spark plugs. why is this other than price $10 a plug? i was going to get iridium ngk plugs but wanted to check with you guys 1st as they are $7 a plug.
    Quote Originally Posted by Acidrain620 View Post
    our cars run the best on oem ngk spark plugs.
    08-13-2008
    Waterbury, CT
    3,331
    ngk coppers are all i run
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    yeah if you treat the motor right it will treat you right,and run strong and last forever.
    04-08-2010
    Springfield, Mass
    1,225
    ive ran E3 spark plugs and ngk iridium
    «Carlos»
    First of all, are they going to be for a stock car?
    I don't know what others had against platinum, but I've run and installed in both my very own and in friends cars platinum and iridium NGK plugs with no issues whatsoever. As a matter of fact I have G-powers in mine right now. Advance sells them for $2.60 btw. Most stores won't stock them (at least around here) but they'll get it by next day. You can read up on the advantages of IR plugs in detail, so I won't bore you with that. In short, platinum plugs will need to be replaced sooner than IR, but that really shouldn't be a concern on an I4. So for a fairly stock I4, I'd def save my money and go with that.
    Now oem style plugs, laser iridium and laser platinum will be superior of course, but they will cost an arm and leg. So if you need better plugs than the G-Power, just go with the Iridium IX line.
    Other than that, just stick with NGK or Denso, but you got that one down.
