https://www.thegalantcenter.org/showthread.php?t=44237
in this thread
I came across the thread a long time ago but cannot find it. It was the wiring diagram to splice a resistor and a capacitor in parallel to your current post cat o2 sensor to remove the mil light. Some one please help. Thanks.
in this thread
thanks. will this work on the v6?
over post
Is not a good idea to mess with o2 sensor. Ur car will run like shit if u get the minimal foult readings front it. Make sure u change all o2's.
I see what u saying but is for a reason is there. All sensor works together not all cars are the same. Ecu are very sensetive when coming to readings. It wont do any good if u are stock to make ajustment to o2s. Turbo i would understant but stock i will leave it oem. Unless u change and tune ecu.
He' has changed the tune - there's no cat
