You move fast.. Great progress.. Pictures!
mmkay so sadly i don't have many in progress pics but ill dig up the ones i have soon for now ill just do a quick runthrough of what I've done, what i want to do and what I'm currently doing.
Got the G back in 2009 right as I moved to mass. did the first few things everyone does CAI, coilovers, subs, headunit, roof mount tv,.......underbody neons, 17" excel rims, and a few other small mods. But there just wasn't enough get up and go in this car for me so i started researching what i could do and how...and luckily have a family garage that does aftermarket performance on cars.
so the next step was to turbo it spent about 3months gathering parts while busting my ass at work. and in january of 2010 started the project took me approx 1-1/2 weeks to finish turboing it then another week to get it right. But it just wasn't enough and i had issues cause i didn't use any engine management and stock ecu+boost=epic fail. so summer 2010d while patrolling the j/y i found a 99 4cyl sonata with a missing valve cover and the head full of water......jackpot....got the head and i/m w/ tb and everything for 100$ even cleaned up the head checked for leaks nothing. just win. so i started putting it on. then when i attempted to use the sonata coilpacks with my ecu my ecu got fried. went to the j/y pulled another galant ecu and what do you know that ones fried already. So fed up i bought an evo8 ecu and started wiring it...couldn't afford boomslang.
finally finish setting it up dual ecu style and lookit that it works i actually got the frikin wiring right i was amazed. Then when i was adding knock sensor and a few other thing a couple pin on the stock ecu got pulled out and now my shifting is starting to go all crazy on me and my maf dies. Picked up a evo 8 maf for 50$ another good deal that fixed half my problems but still shifted like crap not to mention the auto just cant handle the boost i was putting down so it was time for 5-speed, so late 2010 picked up a tranny for keith on tgc with multiple swap parts grab the other few things i needed and got started on that swap took me about 10days to do this swap because of some complications and doing it outside in the freezing rain but finished it and the car was back up and running this time with minimal problems...but about a month later and considerable amounts of boost i started to notice some major oil burning going on whenever i cold started my car damnit.
so i started buying up parts to rebuild the head. pulled it early 2011 fully rebuilt it with all new stuff and studs and put it back on the car...and lookit that burning just as much oil as ever...piston rings *facepalms*. so i took a short break from trying to fix the engine. bought a cyber gt body kit and some new rims about 2weeks ago.
Mods Done
gt-30r turbo
obx turbo manifold
custom downpipe
565cc wrx injectors
evo 8 ecu
xcess wastegate
manual boost controller
type rs bov
cx racing 2.5" intercooler piping
large fmic
egt, water temp, oil press, and boost guages
sonata DOHC head
sonata i/m
aftermarket adjustable fuel pressure regulator
evo 8 cams
eo brian crower upgraded valve springs w/tit retainers
arp evo head studs
eclipse 5-speed tranny
cyber gt body kit(on the car mostly fitted just workin out the front its givin me trouble with the headlights)
17" excel rims( ust bought new 18" rims wating on new tires b4 they go on)
sony headunit
new door speakers 250w rms 500w peak
new 6 x 9s 230w rms 460w peak
precision power pro124 1000w rms 2000w peak flat piston sub
orion cobalt 800w rms 1600w peak amp
trunk mounted battery
ebay adjustable coil springs
boss roof mount tv
green interior neons
altezza tails
oil filter relocator kit
blue adonized oil cooler
drilled slottted rotors
full 2.5" turbo back exhaust
high flow cat
and more that i cant remeber right now ill update when i think of it
Coming Mods
new block
9.5:1 forged pistons
1000hp+ eagle forged rods
stock crank
evo water pump
acl bearings
evo gsc s2 camshafts
powdercoated valve cover
brembo brakes
exedy s4 clutch
lightweight chromoly flywheel
rebuilt tranny( to handle excess of 600hp)
getting the car resprayed ( primer and everything)
GETTING IT DYNO TUNED (deperately needed but i need the new block first)
wideband o2( dont have one yet cause the burnin oil will ruin it)
fix all my exhuast leaks
99 galant harness to get speedo working( not sure if this works but im gonna try)
figure out how to properly wire up the knock sensor
more to come when i think of them but thats all in the works should all be done this year
Summer of last year back when she was still auto and SOHC
The trunk plus fatmat
Oh shiet why isnt that on the car lol
mid-fall last year already DOHC by this point
sonata I/m after some sanding to make it look a little better
Evo 8 adjustable gears! and this pics old i cleaned up a lot of the mess it shows
DOHC painted the letters with some blue paint
My oil filters waaaay up here
OBX mani when it was still new
and lastly a turbo sohc engine pic
since these are all old pics ill be puttin up some new updated ones later today!
2002
4g64 dohc turbo 5-speed
gt30r @20psi stock block,mbc
2.5" tbe
evo 8 ecu and maf
lol thnx some pics will be up today rest will be up tmrw
2002
2.5" tbe
evo 8 ecu and maf
Hmm, I don't see any 5spd pics lol. Its about time I get to see your g! It looks real clean and I love the setup! Now if only I can get ya to do a video haha.
Eclipse GT 5 spd swapped
Rotor Glow Galant
Daily Galant
OZ Edition Eclipse
lol i got tmrw off work ill do a light pull with the camera and throw it on here since im gonna be taking some updated pics anyways.
2002
2.5" tbe
evo 8 ecu and maf
took her to the car wash dunno why but my phone was only takin black n white photos i didnt notice it till now.
this is just the rough fitment of the bodykit and ill be repainting the entire car all at once.
this is how im recirculating my bov for now still looking for a better way to do it.
2002
2.5" tbe
evo 8 ecu and maf
if you notice those wheel gaps, yea im getting much bigger rims very soon just waitin on tires.
2002
2.5" tbe
evo 8 ecu and maf
Yes, please change the wheels. Other than that, nice whip.
thnx i went a lot more go>show starting to hit up the show now though.
2002
2.5" tbe
evo 8 ecu and maf
Got any new pics in color?
why are you running 100 psi fuel pressure?
i did some injector calculations at rc engineering and it bumped the cc's up not sure if it really works but it seems like it does. oh yea and i got the new rims and tires new clutch and lightweight flywheel all installed and done still working on the custom exhaust and just about done welding all the intercooler piping now just an update on what ive done lately lol.
2002
2.5" tbe
evo 8 ecu and maf
ill go take some color pics tmrw got a new phone so i might as well test it out droid ftw
2002
2.5" tbe
evo 8 ecu and maf
this is a little trick used on cars with pressure sensor( hondas). We have MAFs and the AFRs are alternated from the airflow signal.
mm oh well i already had it turned back down a while back i didnt like having the psi that high. thanks for the info though helps to know this stuff.
2002
2.5" tbe
evo 8 ecu and maf
http://youtu.be/CRV93kcZMDM
video of a quick short rev turbos not piped in just n/a rev
and some new updated pics
my new big ass turbo 4in intake o.o
quick little interior shot
btw did i mention the new tires are reaaally wide?
new tig welder which lets me do this!
straight side shot of the new rims their pretty dirty from sittin but they still look nice.
2002
2.5" tbe
evo 8 ecu and maf
