Thread: 01-03 sebring front seat swap
Showing results 1 to 15 of 15
    Ok, so I bought a pair of Sebring seats (black leather) 2 Fronts. I installed both and both fit like a glove, bolted right up...upon hooking up the power driver seat I became stumped. your switch is on the seat wires run from the switch to the motor whic is all underneath the seat, Ive come to the conclusion you just have to feed it power .....but from where thinking of the best closest place to get power from,I used the shifter light power wire which I alredy have my guages drawing power from. the seat works!!! graet...but I just blew a fuse, any ideas anyonpleas help. also realizing aftewr the fact the seat only worked when my running lights and headlights were on. closest possible location with a fuse big enough to handle the power drain?
    thankyou,
    JOE
    why not just run the wire to the fusebox in the dash and use a fuse splitter then you can run the seat power on its own seperate fuse so you can use whatever size you need? They sell the splitter at autozone or advance for like 2-3$ it plugs in somewhere you have a fuse and makes it into two with a pigtail of wire coming off to run another fused power from the same source without drawing from the source thats already there ive been doing this with my gauges.
    2002
    4g64 dohc turbo 5-speed
    gt30r @20psi stock block,mbc
    2.5" tbe
    evo 8 ecu and maf
    Very good point first thing I'n the morning getting one but what size? Do you think would be not too little bot too much?
    Meaning how many amp fuse should i go with
    01-19-2007
    Lyndhurst, NJ
    3,473
    Would you be able to post pictures of the seats?? I'd like to see how they look.. Your other choice is to run a fused dedicated line to the battery..
    02-07-2007
    ORLANDO
    1,599
    or splicing the 12v accessory power line
    Quote Originally Posted by Jeffylou87 View Post
    +1
    '00 Patriot Red GTZ --> JDM'ed... 5 Speed... ...
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by 02redgalant View Post
    ooo, good spot for my wideband! lol
    ill post a pic of what one looks like so you have a reference and i dunno id say try a 15amp for the seats if that blows go up from there.
    2002
    2.5" tbe
    evo 8 ecu and maf
    Ok well i ran a fused line directly from the battery, originally i had a 18 gauge wire which i upgraded to 14 gauge. Blew a 10 amp fuse, put a 15 I'n and it's holding fine. Job well done btw love the seats very comfortable compared to the g seats[IMG][/IMG]
    07-12-2007
    SoCal
    4,632
    Nice, those look alot like my 3G Eclipse seats.
    JDM Zenki Conversion
    Couldn't find eclipseseats anywhere I'm gonna try the kiwi shoe polish (black) this week. Anybody try this?
    Supposedly it works wondors on faded leathers black especially. Btw does anyone know of any rear black leathers that fit back seat?
    Quote Originally Posted by cleazy123 View Post
    Careful with this though, you can get polish all over your clothes if you don't buff it off completely. A little dampness and polish can come off.
    thanks for the look out Tamim13
