from all the post i have read,, i think Freedom Design Rocks,, the only thing i hate is taht red color at the end of the sturt bar,,, its just too god damn bright,,, you can alwasy paint that over,,,
hi..... i just ordered a freedom design strut bar just wondering if anyone has this and if it is good qulity or not and does it make a huge diffrence ???? because i have the stock eclipse one rite not, so is there and diffrence between the two besides how they look?
.....thanks!!!!!
AkA K h O p A r I.
I Am back BitcheZzZ
I like mine alot, and yea, I might be painting mine blue,
ditto there is a noticable difference.
Mine was a pain in the butt to put on but I noticed alot of imporvement when I installed it.
C.J. Cameron
RETIRED TUNER!!!!
"Keeping it Simple"
You'll notice a difference. Definitely stiffens the front end...
(and looks good too)
I have a ?,
Is it hard to actually install the strut bar. I am not mechanically incline, but exactly what would I have to do to install a strut bar. I haved the gtz so i should feel some difference in the ride, am I right or wrong on this....Thanks JOSH
I had a 2001 Dover Pearl White Galant GTZ totaled it in 04
https://www.facebook.com/profile.php?id=1549311946
Well, mine was a biaatch to install.. I think I had a defective batch.. I had to grind inside one of the holes with a dremmel to get mine to fit properly..my shit is tight as hell.. yes you should notice a difference..
mine took like 3 hits with a mallot and went right on... anyone can do it
Where can I get one from? and are there any other better strut bars out there as well?
<div class='quotetop'>QUOTE(ucool80)</div><div class='quotemain'>Where can I get one from? and are there any other better strut bars out there as well?</div>
here is the link for Freedom Design
http://www.clubtgc.org/forum/viewtopic.php?t=6618
AkA K h O p A r I.
I Am back BitcheZzZ
<div class='quotetop'>QUOTE(ChromeGalant)</div><div class='quotemain'>Well, mine was a biaatch to install.. I think I had a defective batch.. I had to grind inside one of the holes with a dremmel to get mine to fit properly..my shit is tight as hell.. yes you should notice a difference..</div>
you too? i did the exact same thing (GOD i love my dremel lol). there probably was a defective batch.... :?
Cali: Sig 3/28/2011
<div class='quotetop'>QUOTE(cali)</div><div class='quotemain'><div class='quotetop'>QUOTE(ChromeGalant)</div><div class='quotemain'>Well, mine was a biaatch to install.. I think I had a defective batch.. I had to grind inside one of the holes with a dremmel to get mine to fit properly..my shit is tight as hell.. yes you should notice a difference..</div>
you too? i did the exact same thing (GOD i love my dremel lol). there probably was a defective batch.... :?</div>
i thought it was 1, 2, 3, setup,, did u use freedom design??
AkA K h O p A r I.
I Am back BitcheZzZ
Nice.. I thought I was the only one... haha....
MUST have been a bad batch..
Kho, it is supposed to be an easy install.. unless you got one from the bad batch...
I lucked out...my strut bar went in perfectly, and now BGR has it. Wonder if he had to do any pounding...
I got mine fairly recently (this winter). It was the easiest thing I've evr done. Just take off the tower bolts and eyeball the unit for length and then fine tune it. I put mine so that it was a little tight getting on so it would do what it's supposed to. I think with no other mods to the suspension you will notice a big difference. If you get the Rear sway bar you'll be in excellent shape for not too much $.
BTW I always assumed with the strut bar you would want to extend it as long as possible when installing...am I wrong about that logic?
<div class='quotetop'>QUOTE(Rallifan)</div><div class='quotemain'>BTW I always assumed with the strut bar you would want to extend it as long as possible when installing...am I wrong about that logic? </div>
I sorta eyeballed mine, made it long enough for everything to fit, then tightened up the adjusting nuts until tight.
Chip
(Paint Code: Porsche LC9Z)
