Where is the flasher mechanism for turn signals?
On super bright LED's site they have these little plug that look like relays but apparently act like load resistors for LED turn signals. Where is our plug located on the 9g? I searched but didn't find a thing.
Here's the link http://www.superbrightleds.com/cgi-b...2Fflashers.htm
Effort and courage are not enough, without purpose and direction.
It's in the ECU located on drivers side under he bonnet.
It's called the front ecu, in amongst all the fuses.
It's controlled by software and emulates the relay clik etc.
