Thread: Inyector Problem? heelp!!!
Showing results 1 to 20 of 22
    Icon9 Inyector Problem? heelp!!!
    have a little problem
    my car pulls (misfire) when going above 2000 rpm, has new wires, new spark plugs. that may be? injector or cap
    distributor or maybe another thing,
    what ya think?
    UPDATED! Videos!!
    please check it!
    http://www.youtube.com/watch?v=0qB_sB7HN2w
    http://www.youtube.com/watch?v=W7_7D-dkt9E
    thankS:D
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    06-16-2010
    Fort Mill, SC
    2,282
    What do you mean by "pulls?" Like to one side or the other?
    Is there a misfire?
    -Andrew
    missfire of course,
    __________________
    04-19-2008
    Texas, Houston
    450
    When was the last time you replaced your coils?
    my coils? what do u mean? the distributor have no coils, :S
    __________________
    04-19-2008
    Texas, Houston
    450
    oh wait, my mistake, im my head, I imagine you having a 8G SOHC. Anyways, if you say it starts to happen at 2k ROM then your piston like the rings or bearings is my guess. Im regarding to that you have already replaced all the others like you said. Usually if it was the injectors then it wouldnt happen at high RPM but lower RPM like when you idle.
    also happend when im going slow, like 20-30kmH
    __________________
    04-19-2008
    Texas, Houston
    450
    How does it feel when you idle?
    am, good, are around 800-900 rpm, and 700 when the fan go in.
    __________________
    the 7g has a single coil and its in the distributor. Its not sold separately as a part.
    Do you have a check engine light on. You have a 96 so the ECu is OBD2 which is pretty sensitive.
    noup, have no check engine.
    __________________
    take a video. its very hard to imagine
    okei, gonna take it later, upload it at the night,
    __________________
    Kleen
    sorry to interupt but i might have the same problem..at normal driving, say about going 40 mph up hill my car surges. like my rpms drop like 2-300 then go back up constantly untill the load is off going on a flat stretch of road. What could this possibly be? again sorry for jumping in on this thread!!
    have u change your spark plugs? wires? fuel filter?
    __________________
    updated
    __________________
    i dont see anything
    04-19-2008
    Texas, Houston
    450
    Nor do I. RPM jumping can mean possibly anything that its one of those problem the mechanic have to drive and see himself for best result of diagnostic. In our case, a vid that shows (lols) would be great help like mko said.
    it can see in the camera movements. the car "jumps"
    __________________
    no I cant see the video link you posted
    EDIT: Fixed
