Thread: Isaurio's Brembo Swap
Showing results 41 to 60 of 61
  1. #41
    First of all special thanks to "DeezNuts" for making the brembo swap.
    i dont think it matters really what side they are put on...but as you see the slotted direction the evo rotors are going are backwards which tells me you put the wrong side rotor on there.
    your stock set-up is correct...
    when i did mine the rotors where labled R&L
    :P i did the same mistake you did and had to change them :)
    Fully Built 4G63
    HKS 272
    ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
  2. #42
    ^^^noticed that after the fact. corrected now...
  3. #43
    Quote Originally Posted by deeznutz View Post
    cool...question did your break pedal become a bit softer after you installed the brembos???
    mines got a lot softer and sometimes i have to push all the way down to stop or double pump the brake pedal..the car stops fine...its just not as sensitive as the stock set up...maybe i need to re-bleed the whole system again...but i also hear its due to the master cylinder not having enough pressure to push the fluid to these massive calipers...changing to an evo booster and master cylinder should fix the problem 100%...
    Fully Built 4G63
    HKS 272
  4. #44
    Experienced TGC Member njjfudge's Avatar
    02-28-2005
    Jonesboro, GA
    1,447
    Quote Originally Posted by whokilledhoughes View Post
    You need to re-bleed you have air in your system. Did you bleed both sides of the callers? If your system is full of fluid and all the air removed like it should be your stock master cylinder should have no problem moving the fluid.
  5. #45
    x2 re-bleed your system.
  6. #46
    will try that again...cause sometimes the brakes are scary soft and feels like they wont stop in time.
    Fully Built 4G63
    HKS 272
  7. #47
    Your g looks great with them brembos bro!!!!
  8. #48
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    It does matter, most Evo and performance oriented rotors in general have directional cooling veins sandwiched in between the rotor and have to face a certain direction in order to work properely, the direction of the slots on the outside of the rotor doesnt mean anything. Thats why the rotor with black caliper has an R on it. I dont know which rotor the other one is, it looks like an older Power Slot but they usually stamp the orientation on the hub of the rotor. It may even have straight veins in which case it doesnt matter which way they face. I'd check with the instruction sheet, the label of the box they came in or contact the manufacturer to get the final say.
    Looking good so far though! Keep it up bro
  9. #49
    05-01-2008
    Manitoba
    1,589
    Nice brakes bro! Nice upgrade!
    Tuned 2013 Evolution X GSR PB
  10. #50
    06-13-2008
    Bronx, NY
    2,606
    Thanks everyone. Yes it did get a lil softer the break pedal. after a second bleed is way better now. Breaking system is a super plus.
    SOHC Turbo
  11. #51
    12-13-2010
    Brooklyn, Maryland
    4,643
    Quick question, does anyone know what wheel offset is needed to clear these Brembos? My searching isn't coming up with a clear answer.
    -Greg
  12. #52
    ^its a combo between offset and wheel design, I know stewi has some konigs with 30mm offset I believe, his cleared the brembos, mine are 30mm offset and don't clear brembos, Ihave to run a ten mill spacer...
  13. #53
    i bought stewi's old wheels. they are the perfect fit, barely clearing the brembos. like galantman said its a combo between design and offset
    Fully Built 4G63
    HKS 272
  14. #54
    06-13-2008
    Bronx, NY
    2,606
    Yeah i have the g35 rims offset +30 and is a close one. Is a trial and error. Best place to look for one is evom since all their rims are just for brembos. U could get a idea of their rims offset.
    SOHC Turbo
  15. #55
    12-13-2010
    Brooklyn, Maryland
    4,643
    Ahh, I can see that, how they curve the spokes and all, thanx for the answers fellas!
    -Greg
  16. #56
    02-28-2005
    Jonesboro, GA
    1,447
    My wheels are +32 offset and clear they brembos by a lot. One thing I looked for when I bought my rim was the space between the back of the spokes and where the rim contacts the rotor.
  17. #57
    part numbers for the bolts and washers
    front bolts x4 MR370729
    front washers x4 MR407072
    rear blots x4 MR370730
    rear washers x4 MR407073
    and for those needing a vin# for a Evo---2005 Evo 8 JA3AH86D75U034182
  18. #58
    I know its old thread but... What rotors are you guys using for the rear?
  19. #59
    Evo's rear
  20. #60
    Thanks for the info. I never got bolts with mine and this is gonna make it much easier on me. Lets consider this repayment for making u laugh twice this week lol
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
