Thread: Control arm
Showing results 1 to 4 of 4
    Control arm
    Hey does anybody know if an 04 GTS control arm is interchangeable with the eclipse. I'm looking for a drivers side control arm and can't find one listed for 04 galant GTS. THANKS
    The GTS is 3.8 or 2.4? Here's a link to see the listed Control arms -
    http://www.oemmitsubishiparts.com/pa...layCatalogid=0
    It's 3.8 thanks for the website. Is there an upper and lower control arm on front driver side? Only lists lower.
    I don't think so. A 9g guy might be able to answer it better, but for the 8g there isn't an upper control arm in the front.
