looks like fun
heres some of the pics i of the install
i just want to say thanx to isaurio for helping me with my idle issue
me starting to tear into it,
me checking inspecting and double checking my work
the huge crack as you can see,
INTAKE fully assemble
Can anyone guess what I did?
Made a bracket for the throttle cable
HTC EVO 4G
MODS
5 speed swap
Eibach Pro Kit on GR2 Struts
Cold Air Intake
Outlander Intake Manifold
6G72 V6 Throttle Body
6G72 V6 Fuel Pump
Axle Back Exhaust (ebay)
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Prothane Motor Mount Inserts
Does it work right putting the relays where you did?
«Carlos»
Yes, its more protected from the elements, all I did was de pin it from its socket one at a time and placed it in the main fuse box,
There's two spots for relays Togo, fogs and headlights
If you like ill post a how to on home I did it but its self explanatory
HTC EVO 4G
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
I was reading another thread about intake spacers from outlaw engineering, only thing is they don't have one for the 4g64, will the one from a 4g63 work
http://www.outlawengineering.com/mitsu4g6395frame.html
What are your thoughts on this.
Sent from my PC36100 using Tapatalk
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Has any one put an intake mani from an EVO on the 2.4 head?, if so it would work,
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Does anyone make one for the 4g64 at all?
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Picked this up last night for 300$ with everything to do the swap.
I'm Gona use the clutch kit that it came with since its still new and only has 1000 miles on it.
Also just order new shift linkage bushings and a few other things
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
