Thread: Finald8ta build
Page 9 of 11 FirstFirst ... 567891011 LastLast
Showing results 161 to 180 of 211
  1. #161
    I used the evo oil.pickup
  2. #162
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    This is a pic from Pale Horse on Club3g,
    Top one is the evo with its pick up and bottom one is the 2.4:
    4g64T 5spd
  3. #163
    02-17-2011
    i live in sunny florida
    1,240
    thx Omega Phx for the visual, just picked up a evo 9 maf and WRX 440 injectors,
    soon ill be working on a pnp harness for the evo 8 ecu
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
  4. #164
    You definitely have to use the evo pickup with the pan. On my first car I didnt know this since it is one of things that gets swept under the rug. I ended up picking one up.
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  5. #165
    02-17-2011
    1,240
    Quote Originally Posted by Ivory8g View Post
    if you come across another let me kno. i plan to use the stock evo dowpipe as well and run a high flow cat with a cat back exhaust,
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  6. #166
    For sure man! I think I know of one for sale actually. Let me see if its still available
  7. #167
    I wonder what might happen? actually idk if it will fit lol
  8. #168
    05-03-2009
    1,465
    I posted a pic above with both oil pans side by side, there you can see that the pick up enters in a different place on the evo one therefore you need the evo pick up to be able to install that pan
    4g64T 5spd
  9. #169
    Finald8ta build
    Yep pretty much. On ivory i even cut the old pickup and had it welded and it still wasn't right.
  10. #170
    I know what they look like, I had to swap them out also. I was stating that, even that they bolt up to the same spot, if you manage to fit the the 4g63 oil pan with the 64 pick up tube, I wonder what the effects would be.
  11. #171
    02-17-2011
    1,240
    getting close just bought another evo8 turbo for real cheap, also down pipe and o2 housing came in, no sure if im going to use the oil sandwich adapt of pick up a evo oil filter houseing yet, also got stainless braided oil and water line as well, just need to figure out the rest of the length to where it will connect to, ill do that once i have it all mocked up, still need a wide band, boost gauge, oil pan, exhaust flanges, and intercooler
    should i use the evo FPR or run an after market one? i picked up a fpr adapter and guage.
    oil pan is questionable, not sure if i can find a evo one for cheap or just modify the stocker
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  12. #172
    Quote Originally Posted by finald8ta View Post
    Nice!!! A lot of people are going with the evo filter housing since it sits up higher. I had a greddy sandwich adapter plate and am rocking that. I use mitsu filters so maybe thats why it seems to sit higher up this time around. I used the stock evo fpr both times and its awesome. 1:1 rising rate is all you need until you need to start running specific fuel pressure to get every drop of flow out of your fuel system. The oil pan and pickup is just a searching game
  13. #173
    02-17-2011
    1,240
    Had a blast getting the G dyno, video and pics will be up shortly
    Sent from my PG86100 using Tapatalk 2
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  14. #174
    06-13-2008
    Bronx, NY
    2,606
    Cant bee done. The g oil pick up tube is way long. Even if u cut the evo pan to fit the g pick up is inches alway from touching the bottom of the pan. Not good for oil flow, you will end up bottlenecking the oil flow.
    SOHC Turbo
  15. #175
    06-13-2008
    Bronx, NY
    2,606
    Keep us posted.
    SOHC Turbo
  16. #176
    02-17-2011
    1,240
    let me kno what you guys think, she really needs a tune to maximize all the mods i have
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  17. #177
    05-03-2009
    1,465
    A tune would make a little more power and make it smoother, but if your going turbo I wouldn't waste money for a n/a tune
    4g64T 5spd
  18. #178
    02-17-2011
    1,240
    it will be some time before i go boost, before i go boost i like todo some autox, and get a feel the car before i go boost,
    i have my own reasons for this, i just dont want to go straight into autox with a turbo car,
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  19. #179
    12-13-2010
    Brooklyn, Maryland
    4,643
    I enjoyed that video, had a big smile on my face, it sounds so much like my old car! Man I miss that car, that 4-banger has a distinctive sound. All things considered that's not bad for a fully stock motor, but yeah I'd think you could gain a little more from bolt-ons, but I guess that all depends on the tune.
    -Greg
  20. #180
    02-17-2011
    1,240
    same here man, i was smiling from ear to ear, i told him to bring it to redline, if i didnt have an exhaust leak it have a more deeper tone,
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
