Thread: Lips and bumper for 9G
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 48
    I want to tell you how did lips and bumper for 9G. My old 9G 2004. I want more individuality.At first i drew in the program "Photoshop S2", what i want.Strongly do not swear, drew as he could. [/quote]
    First, i take the base for the lips. They are made of plastic.
    Install the bumper on the base. Use construction foam and do lips.Once the foam has dried, remove unnecessary. So i do coating of paper tape.
    In the paper we draw the line cut. Cut off a sharp knife unnecessary. Attention! Not cut the power tool.
    That 's what happened.
    Lips cover filler and remove from the base.
    Sandpaper begin to display the desired shape.
    The part of the stick on the bumper with a tape.
    Put the dividing layer.
    Use resin and fiberglass. Fabric use three of a kind. Thin, medium and thick. Layers of landscape so thin, medium, thick, medium, 2 thin. Total: 6 layers.
    After drying, remove the lips and take out the inside of the foam.
    Cut off the excess fabric. Drilling holes, the lips are almost ready.
    Then put on lip fillers.
    [url=http://www.radikal.ru] It is necessary to get a good surface.
    Temporarily defer lips.Now you must make the mouth of the bumper.First use of a soldering iron. The part that was cut off earlier, welded to the bumper.
    Now need hairdryer. T 400С
    On the inner side of the bumper written kind of polypropylene. You need to pick up the solder on the number. The welding seam to do with the two parties. It is a monolithic structure.
    Further it is necessary to strengthen the inner side of the bumper foam.
    Now you can paste the lips to the bumper
