Thread: A supersupercharger on Galant 9
Page 4 of 6 FirstFirst 123456 LastLast
Showing results 61 to 80 of 116
  1. #61
    I'm thinking also to buy this product. But, I think, price will not be low... :( No wonder - handmade!
  2. #62
    Boris, we must wait for serial production. The price will be acceptable.
  3. #63
    Quote Originally Posted by stayer View Post
    It will be great, mate! I wait completion of work.... Good luck!
  4. #64
    10-05-2008
    Grand Rapids Michigan
    1,141
    #brokenenglish
  5. #65
    I wish this was mad for an 8g galant 4g64
  6. #66
    Initially, I only wanted to install a supercharger. However, in the course of the project, it was found out, that there are very many people who want to install a package. I understood that I can give it to people. Therefore, the project was at a military factory. At this point in the development of 2 variants of the compressor. 1) For engines up to 2.7 liters. 2) For engines up to 5 liters. The options have in the same gear, but the different size of the snail and the impeller. Tonight I will show you the difference between the snails.
  7. #67
    Previously I have selected the impeller from the various turbochargers. The project lasts for a year. During this time I was able to contact the manufacturer of turbines, CZ. I made drawings of the impeller. During the month I promised to make the party of the impeller.
  8. #68
    We Will Continue. I want to tell about the snail for the variant №2. The turbocharger is selected in size and is calculated according to the formula of air flow. I need this charger. For the first sample I took the used snail from the turbocharger. To use it is necessary to spend tuning.
  9. #69
    First, increased the center hole of the input. Now it is 3.5" (89.5 mm) For the new impeller. Hole output 2" (50 mm). The entire enclosure is processed by the sand of the jet machine.
  10. #70
    Here is a picture for comparison. To the left version for engine 2.7 litres. On the right side for 5 liter engine.
  11. #71
    As you can see in the photo, in 5 litre version, there are studs. It is necessary to make the transition to the pipe. I will tell you how it is done. First is worked out the piece of steel. The second part of the standard pipe transition with a diameter of 52 mm to 70 mm.
  12. #72
    On the reverse side parts made recessing for the rubber ring. Just set the diameter of the holes.
  13. #73
    according to the set diameter are three holes through the 120 degrees.
  14. #74
    Next, hold the welding works, using argon. The result was a metallic glass.
  15. #75
    A further step, polishing machine. After 30 minutes the glass looks like this.
  16. #76
    So it will be installed. On this day all.
  17. #77
    11-29-2009
    Chadds Ford, PA
    2,768
    WOW so pretty
  18. #78
    12-13-2010
    Brooklyn, Maryland
    4,643
    Stas is talented for real!! Good stuff bro!
    -Greg
  19. #79
    A small bar to the product. With the help of a laser.
  20. #80
    Yesterday finished the work on the coordinate machine. These works are performed in assembled form. Housing and cover screws are tightened, after that are made holes.
Tags for this Thread
