Thread: Clear coat or Not?
Showing results 1 to 8 of 8
    Clear coat or Not?
    Hey guys, just needed some advice, I painted some interior trims and was wondering should i clear coat them?
    1.If i clear coat would it be to shiny?
    2.If not clear coated would it scratch easily?
    06-16-2010
    Fort Mill, SC
    2,282
    Yes! Clear them! I made that mistake and had to redo everything.
    Sent from my iPod touch using Tapatalk
    -Andrew
    06-13-2008
    Bronx, NY
    2,606
    YES CLEAR THEM. The benefits are:
    shiny
    looks good
    if you scratch them you could always buff it out.
    Make sure you put a least 3 coats.
    SOHC Turbo
    TGC Regular djhah's Avatar
    03-15-2010
    nashville, tn
    505
    You can buy low gloss cc.
    Ok thanks guys,i'm about to go pick some up right now. Hopefully i can get my door panels and stuff back in by tonight.
    What kind of paint did you use? And certainly clear coat!
    I used PlastiKote Vinyl paint. And yes i clear coated, it came out pretty nice.
    Now contemplating on doing bottom half of my dash Tomorrow.
    Ah I used krylon fusion for mine, Stuff works wonders especially if you rough up the surface a bit first.
