Thread: Rear emblem
Showing results 1 to 20 of 23
    DjFlav3
    Rear emblem
    Hey G center I was thinking about shaving my rear emblems (the galant and the mitsu emblem) and was wondering if any knew if the rear mitsu emblem is glued on or if there's a 'peg' on the rear. In other words if I remove it will there be a hole I have to fill. Any feedbacks appreciated thanks.
    Pretty sure they are adhesive applied.
    Member SirSaula's Avatar
    11-20-2010
    Dallas, Texas (Lubbock)
    286
    Depends the 2007 rear emblem will leave a hole.
    9th Generation Mitsubishi G
    TGC Texas Chapter
    Friends don't let friends drive stock. Ever
    04-19-2008
    Texas, Houston
    450
    all G models leave holes
    It has 3 holes about 5/16 diameter and it also has doublesided tape e . This is for a 2006 galant .
    DjFlav3
    Ok I'm assuming it would be the same for an 09.
    2010 has a hole in the trunk
    Doublesided tape for inscriptions and holes for the logo. I shaving the logo.
    05-31-2005
    4,735
    holes all over.
    I Used a heatgun on the emblem to loosen the adhesive. Be careful though that you don't melt the paint.
    DjFlav3
    Yea on my Acura we used a hair dryer to loosen the glue. The more you loosen it the less sticky crap you have to take off with goo gone afterwards.
    04-19-2008
    Texas, Houston
    450
    hair dryer is safer. Hair dryer > floss > goo gone. Done
    Today i removed the emblem of the "Mitsubishi" and made RalliArt. Front emblem RalliArt as well. I have not used the hair dryer. Simply removed the knife and cleaning solvent for paints. No holes., only double sided tape.
    Ive had the same problem. 2011 GALANT
    I took my heat gun and slowly took off the back emblems. Then i find the middle EMBLEM has two holes in the back!! ! What a mistake. This was about 2 weeks ago, i can not find a BLACK EMBLEM...the ones ive found on ebay are cheap carbon fiber black
    http://cgi.ebay.com/ebaymotors/REAL-...item336a707ee2
    ...i think i might try them out or just go back to the OEM. Any suggestions??
    PS: Anybody know the size of the back emblem that covers the holes?
    Link below shows dimension of rear (trunk) DSM emblem. That ebay emblem looks like 3 diamond pcs that you put together like a puzzle. Not a one piece
    i spray painted my emblem matte black and put it back on. i also spray painted the "GALANT" black and managed to turn it into "AJ" and put it back on. The chrome trim and emblem on my grill is also black now :)
