Thread: Passenger turn sig and taillight out
Showing results 1 to 12 of 12
    WyteFang
    ok so my 9g's tail light and turnsignal on the passenger side is out, but when i brake or turn the turn sig on they work but its like there is no constant power, i checked the fuse and i was blown, i replaced it and for awhile, problem fixed but after a while it blows again, what could be a possible fix iam being stationed in Germany soon and my car has to be fully functional to sip, please help guys
    i think there is a relay for the turn siginal to.do you have an aftermarket radio in the car?
    WyteFang
    yes i have a after market radio
    Quote Originally Posted by WyteFang View Post
    did you put it in or was it professionally installed?someimes the wires in the radio effect lights and things.do you have a system in it too.
    WyteFang
    no i did with no system
    06-16-2010
    Fort Mill, SC
    2,282
    Swap the bulbs?
    Sent from my iPod touch using Tapatalk
    -Andrew
    DjFlav3
    I would start by checking the fuses, and after that check the relay for the turn signals.
    WyteFang
    fixed it the radio's groung was connected really loose redid the wiring and boom prob fix
    06-16-2010
    Fort Mill, SC
    2,282
    OT: You're shipping the car to Germany?
    -Andrew
    i knew it most likely had something to do with the radio i seen that happen a couple times before
    WyteFang
    yea its goin to germany
    06-16-2010
    Fort Mill, SC
    2,282
    How come?
    -Andrew
