Thread: Cut my antilock/ brake wires
Showing results 1 to 7 of 7
    Member SirSaula's Avatar
    11-20-2010
    Dallas, Texas (Lubbock)
    286
    Was installing some subs and accidently sliced my antilock and also my brake wires. So now the Brake and anti lock wires stay on in the car. I am attempting to reconnect them back together.
    Any tips/suggestions?
    Please help I don't know If i should be panicking and sweating or not. Will it be fully functional if i reconnect the wires?
    9th Generation Mitsubishi G
    TGC Texas Chapter
    Friends don't let friends drive stock. Ever
    06-16-2010
    Fort Mill, SC
    2,282
    As far as I know, yes. Just use butt connectors and crimp them tight. Should be good as new.
    Sent from my iPod touch using Tapatalk
    -Andrew
    11-20-2010
    286
    Okay thx for assurance was gonna go to dealer.
    TGC Texas Chapter
    just check for fuses, incase they blew when you cut the wires
    11-20-2010
    286
    Taking it to a mechanic tomorrow I don't have the proper tools in order to fix the issue. The wheel/tire is in the way. Sigh
    TGC Texas Chapter
    11-20-2010
    286
    yep taking it in now my A/C doesn't work just the fan
    TGC Texas Chapter
    you need a MUT3 to clear the code, an ordinary obd2 tester will not clear it.
    did the same myself a while back...:(
