Thread: COIL PACKS
Showing results 1 to 7 of 7
    MTOWN_ES
    COIL PACKS
    HEY WHAT'S UP EVERYBODY??? THIS IS MY FIRST POST BECAUSE I COULDN'T FIND THE ANSWER TO MY QUESTION IN THE FORUM............. I HAVE TO REPLACE THE COIL PACKS BECAUSE MY CAR HAS BEEN HESITATING.... ARE THERE ANY AFTERMARKET PRODUCTS I CAN LOOK FOR OR DO I NEED TO CONTACT THE LOCAL MITSU DEALERSHIP?
    THANKS
    here is the list of all aftermarket,, parts,,http://pinoyesv6.galants.com/partslist.htm
    AkA K h O p A r I.
    I Am back BitcheZzZ
    since you are replacing u might as well upgrade. call MSD ignition.
    http://www.msdignition.com/
    D03GTZ
    Who says the coil packs are bad? Just wondering
    toc8g
    Ok Homie,...You looked in the Forum, but did you look in the right Forum,.. I question this because you posted this here. I ran a search and pulled a bunch of stuff up. These might help you.
    http://www.clubtgc.org/forum/viewtopic.php...ight=coil+packs
    http://www.clubtgc.org/forum/viewtopic.php?t=10714
    I had this problem, I am 100% positive its the spark plugs. I only had to replace my coil packs once. It was on my 2000 I-4. I have a extra set brand new. Anyhow i thought it might be my coil packs again but this car was too new. Go buy the oem spark plugs they are like 2 bucks each. Then reset your ecu.
    its not the coil packs, so dont waste your money.
    Also, loose the CAPS LOCK.
    toc8g
    Quote Originally Posted by manybrews
    The Master Mechanic has spoken! I think this topic has been answered!
