Thread: Will these fit?
Showing results 1 to 7 of 7
    Will these fit?
    I have a 2003 Galant GTZ. Tires are 205/55/16. Would I be able to use these wheels?
    http://stjoseph.craigslist.org/pts/2269122698.html
    They're from a Cavalier, with the same size tires.
    why would you put these on a GTZ? GTZ wheels are much nicer.
    Oh, I know. I love the GTZ wheels. I need the tires, not the wheels, but for $125 for the set with four free wheels, I want to buy them. I will be using the wheels for a short period of time.
    It sucks being unemployed and broke, and my right rear tire won't keep air at all anymore. This seems like a quick fix until I can afford new Yokohamas or something.
    I think Galant's bolt pattern is 5x114.3
    The cavalier is supposed to be 5x100. Ours is 5x114.3, so it won't fit. Why don't you buy a used tire and replace the one tire that's leaking? That's what I did until I could afford new tires. Most used shops should charge you about $50 for the tire along with mounting it.
    The tires in that craigslist ad look like junk. I'd pass.
    I actually solved the problem this morning. I went ahead and bought another used tire(I have three tires that I've bought used over the past year or so. The fourth tire is one of the tires I had when I bought the car, about a year and a half ago).
    However, I have another used tire in my house. I'll go get it mounted tomorrow.
    The tire was $15, and mounting it was $12.50. Pretty good deal, IMO. I could have had it balanced, but I think I'll just get all of my tires balanced tomorrow.
