Thread: Intermittent clutch preassure loss
Showing results 1 to 3 of 3
    Intermittent clutch pressure loss
    Hi everyone,
    Back again with a new problem. 94 galant loosing clutch pedal preassure every once in a while. Thought it was the master clutch cylinder so I replaced that yesterday. Clutch, preassure plate, and throwout bearing were replaced a few months ago. A few weeks after I changed the slave cylinder. Theres no leak as far as I can tell. The fluid levels do not change.
    The problem was more noticeable after the clutch was changed. Any Ideas?
    08-04-2003
    NY
    4,344
    How is the line? Is it kinked, maybe cracked and has a slow leak?
    99' Galant ES
    4G64/63T
    AEM EMS
    Bronx NYC (reppin)
    3,489
    try bleeding some more since you said you replace the slave and master.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
