Thread: Where are the flasher relays located??
Showing results 1 to 3 of 3
    I've done tons of searching and checking up on this and I can't find my turn signal or hazard flashers. I'm trying to replace the turn signal relay with an electric relay to get rid of the "hyperflashing" issue. My Chilton manual says they're under the dash on the left side by the fusebox, but all I see there are the accessory relays? Anyone know exactly where they are?
    Here are the fan and accessory relays:
    and i don't see anything in the upper part of the dash either...
    So maybe i'm just blind, but I can't seem to find these. any help is greatly appreciated.
    I know this is an old post... but were you able to find the relays? I thought that the two relays on the fusebox were the flasher relays.
    My turn signals won't blink, someone said that I need to replace the flasher relay.
    The flasher is located directly behind the driver side dash speaker
    You must reach through the speaker cutout to pull it out
    Small hands are a must but its not an easy pull so your kid might struggle
    Old thread figured I'd go ahead and provide the answer
    Me I'm a lil of both
