Thread: aftermarket alarm install for the 9g
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 41
    Hi guys, im finnally buying an alarm system for my whip. I think im going with (Magnadyne PLUS-6900 Convertible Combo) from Sonic Electronix. i know it sais convertibles but it comes with alot of sensors which I could use. my key had a chip. so does that mean i need another key or can i get a bypass modual? Also I want to try and do this myself. can someone help me with the wireing? any diagrams?
    North Bay...NorCal
    2,552
    never heard of that brand...how much is it? You could get a better one for the same price, a little more or a little less. The one I got has tons of options and sensors, color remote, code hoping and more for 250. You gotta figure since its designed for a convertible that most of the functions will be unused in your car and thus a waste of money
    Never heard of that brand, looks cheesy.
    You will need a Universal bypass module with an extra key to keep in the module and it stays under the dash.
    Can't go wrong with this.
    http://www.sonicelectronix.com/item_...p-n-5702V.html
    Wiring
    http://www.the12volt.com/installbay/...asp~TID~109500
    thanx guys. what alarm system you guys runnin?
    On my G: Viper 5900 SST
    Girl's G: Viper 791XV
    My Tahoe:Viper 5901, with the SmartStart Activated (On my Phone)
    wow!! aight ima look into the viper systems. thanks.
    its a name brand "viper" alarm systems. They have remote starting with two way remotes, all the high tech things. for example they also have models where you can now open you car or start it from your iphone. they are pretty expensive but i guess there worth it if you have alot of accessories hooked up to your car.
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    Go with anything made by DEI (viper, python, clifford)
    I have a python 991 as well as a viper VSS5000 (smart start)
    also if you need wiring diagram, look at the stickie threads. I Gave the updated spec sheets.
    allright so i got my alarm system. I ended up goin with a unit from EXCALIBUR. it has a remote start as well. Im having trouble finding my cars wireing diagram online and this is going to be my first alarm install. I understand that i also need to get a bypass modual to trick the computer into letting it think there is a key inside the ignition right? please help, im a little confused. Is there a step by step how to anywhere?
    Really should have went with something from Directed. :smh:
    Yes you will need a bypass module. Check the audio section for 9G's for that alarm/Remote start thread.
    i did i could not find anything for the 9g. Also it came in the mail and now im kind of regreting it just because nobody wants to touch it because there not familir with that brand. im not sure on the match up of the wireing. and also if i need an exra key. some place i talked to said i didnt and others said i did. im cnfused.
    What model is it?
    arent the python 991 and viper 5901 the same?
    01-10-2008
    1,848
    Quote Originally Posted by Joker96 View Post
    exactly alike, the only difference is the style of the remote.
    01-10-2008
    1,848
    Quote Originally Posted by kidfresh89 View Post
    that's why we told you do go with something by DEI
    price difference 199$ for python 991 and 239$ for viper 5901
    im going to return it. I thought i would be able to install this myself but im now im rethinking my decicion because i dont know where to start.
    What model is it?
    Omega Excalibur AL-2030-EDPB. http://www.sonicelectronix.com/item_...2030-EDPB.html
    So what is exactly needed to get the remote start working?? Besides the extra key i guess. I read somewhere that the alarm reads the doors trunk and hood status from the ecu. That i need to buy something to connect the alarm to the ecu. Is that true?? Am talking bout that viper 5901
