Thread: aftermarket alarm install for the 9g
Showing results 21 to 40 of 41
    Quote Originally Posted by Joker96 View Post
    So what is exactly needed to get the remote start working?? Besides the extra key i guess. I read somewhere that the alarm reads the doors trunk and hood status from the ecu. That i need to buy something to connect the alarm to the ecu. Is that true?? Am talking bout that viper 5901
    Not all cars are that way or alarms, that is what DEI calls D2D. Where the alarm wires connect to a special all in one bypass module (even has no key required to operate) and only one wire from the special module goes to a wire on the OBDII port on the car.
    If you really want to install this yourself I can help you, but to be completely honest, you should have a professional do this whether at mom-pop shop or take it to Best Buy. You don't wanna get cheap on this upgrade or any for that matter. You will run the risk of the alarm going bad since it isn't that great, (Things like one day the car won't start with a key or the doors don't lock, or the sensors go bad) if the price difference between that and a Viper was only ten bucks why didn't you get the better known brand? Did you buy from sonicelectronix? They have Viper too you know.
    DEI FTW!!!!
    Does the 8g need a bypass???
    I just got me a clifford alarm i want to get install
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    Quote Originally Posted by BassinG View Post
    Not always. What year is yours? What model?
    Sent from my DROIDX using Tapatalk
    It's an 01 ES.
    i have a clifford 20.7x
    01-10-2008
    1,848
    It's an 01 ES.
    Yes you should need one
    Where can i get the module... im looking on ebay right now.
    Not sure which one will work for my 8g
    01-10-2008
    1,848
    Dei 556uw plus you will need another key to put inside the bypass
    01-10-2008
    1,848
    Is this just an alarm or alarm and remote starts? The bypass is only needed for a remote start.
    other key? what key?
    01-10-2008
    1,848
    Like a key you use to start the car
    damn that means i have to get another key made.... there is no module that doesn't reqiure a key?
    01-10-2008
    1,848
    No there isn't. Again, is this unit a remote start?
    01-10-2008
    1,848
    Ok then yes for sure. Should be able to get the bypass, key, and key programmed for under $80-$100.
    TGC Regular Redhaze's Avatar
    10-02-2010
    North Carolina
    774
    do you need a key for the 03 model
    -Dirty South-
    01-10-2008
    1,848
    Yes
    Is it possible to reprogram a key from another galant???
    I have a key to my bro's old 8g that got repo'd
    01-10-2008
    1,848
    Ask your dealer. But I would assume so.
  19. #39
    12-13-2010
    Brooklyn, Maryland
    4,643
    fliegendaffe (and any other knowledgeable member), if you need a programmed key for a bypass, would you still need a key with a chip for the ignition when you do get in the car and drive off? Does the bypass basically disarm the passive security permanently or only when you remote start? I have two keys and a valet key, so I'm not worried either way, but just wondering.
    -Greg
  20. #40
    01-10-2008
    1,848
    Yes you would and it only does it during remote start.
