Thread: Cluster from V6 into I4 !!!
Showing results 1 to 20 of 25
    NEWBIE Thales's Avatar
    08-08-2010
    Nicosia - Cyprus - S/E of Mediterranean Sea
    17
    Hi everyone....
    I've purchased a VRM v6 Cluster....
    Fit it nicely in my car... all light up beautifully I've got pics too...
    BUT I'm having wrong RPM reading cause I4 has different voltage...
    HAS ANYONE got a clue how to correct it ???
    JDM 1997 Galant VR-G [8th Gen]
    4G93 GDI DOHC
    08-08-2010
    17
    IGNITION ON
    4G93 GDI DOHC
    08-08-2010
    17
    IT LIGHTS ON ONLY WHEN YOU SWITCH THE LIGHTS ON
    4G93 GDI DOHC
    try swapping the tachometer from the i4 gauges into the v6 frame.
    08-08-2010
    17
    SAME PHOTO WITH CAMERA FLASH ON
    4G93 GDI DOHC
    08-08-2010
    17
    you mean the RPM unit....
    hm I will give it a go... but I was looking something like changing a resistor or two to get the correct current that i4 needs I know for sure that i4 needs less from what V6 gives...
    4G93 GDI DOHC
    08-08-2010
    17
    it's funny when the engine hits the limiter but rpm dials shows only 4500 !!! :D
    4G93 GDI DOHC
    02-17-2011
    i live in sunny florida
    1,240
    what makes these gauges much more brighter then the usdm ones? i like to kno iif us usdm can use this set up?
    08-08-2010
    17
    on the vrg version the front plastic cover is in clear see through
    on the vrm version it's black (tinted)
    also the lighting I believe it uses LED....
    I'll take some photos of the back housing of the cluster so u can see if it fits on the USDM Galants.
    4G93 GDI DOHC
    just 180 km/h?
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    08-08-2010
    17
    RAKS_22:
    The Japan cars have a limit on 180Km/h but it goes faster than that !!!
    I've done 200km/h
    4G93 GDI DOHC
    hoo, nice.. i say that because our usdm 7g have 220 in cluster.
    __________________
    does it have adjustable lighting?
    08-08-2010
    17
    Rabbi1991:
    No its one level all day long ! :)
    4G93 GDI DOHC
    the JDM high viz dash(vr-4, vr-m and some 2.4 Viento GDI's) are lightten up by 1 sngle 3mm CCFL bulb,they are brightness adjustable in them.i have on my blue wagon changed the white ccfl for a blue led strip,view garage for pics.
    as for a V6 Dash running on a I4,NO cAN DO, it wont work so dont waste your time..
    1 step better i will swap you a high viz I4 dash cluster(looks identicle to your vr-M one) for your vr-M 1,as i have a 2.l mivec v^ im going to be rebirthing in the Legnum..
    please either let me know or if you know where i can get myself a vrM 1 from please
    pm me if you want
    www.qcustoms.co.nz
    08-08-2010
    17
    qcustoms:
    How good r u with electronics ???
    Why I'm asking?
    cause... I wanted to find a way... I striped the clusters all the way...
    I removed the circuit boards on both clusters (I4 and V6)
    I took notes on the boards and pointed out the differences...
    I've got basic knowledge on electronics from college... so I made the modifications on the transistors... made the v6 to match the I4...
    then swap the IC chip.... put it all back together...
    and guess what??? It worked...
    It's easy as it sounds... It takes time and research...
    but it can been done...
    4G93 GDI DOHC
    08-08-2010
    17
    qcustoms:
    but I did like the blue LED swap....
    I'll consider it... As I did mod the Climate Control Unit into blue LEDs and
    also I swap over the orange LEDs to red LEDs on the two buttons.
    4G93 GDI DOHC
    Quote Originally Posted by Thales View Post
    qcustoms:
    'thats cool im also entry level can you pm me what you did for that?(cluster that is)
    i know with the vr4 dash if you want to run it in a N/A V6 you need to simply swap the rev counter internals over and it works fine(so i tried it this weekend and it did work,however the rev count needle did not lgiht up),but didnt think the i4 would allow such a huge mod as you need to bridge a power feed for the ccfl bulb anyhow,well i did on wifeys galant did you have to?
    im realy interested in seeing how you acheived it and what you had to change aswell
    www.qcustoms.co.nz
    08-08-2010
    17
    I'll take photos, step by step for everyone to see... :)
    I think some people would like to know how you can do this...
    Quote Originally Posted by qcustoms View Post
    4G93 GDI DOHC
    update dude??
    www.qcustoms.co.nz
