Thread: The Money Pit!
Page 16 of 36 FirstFirst ... 612131415161718192026 ... LastLast
Showing results 301 to 320 of 710
  1. #301
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by greddy View Post
    Sex. You sir are living my dream if I didn't use the galant as a dual purpose vehicle. I'm interested in that half shaft solution you mentioned because I too am having some torque steer issues.
    The only OE intermediate shaft for the 4G64/4G69 is the one off the 04-06 Ralliart Lancer. I which I knew the length.
    1994 GS FYI
    DSM/CSM Manuals
  2. #302
    12-13-2010
    Brooklyn, Maryland
    4,643
    Ohh, I can't wait to see this in person! It's supposed to get warmer later this week, I can run to Crazy Ray's and get a set of USDM mirrors if you have no luck with the Mirage glass or anyone else swapping for the JDM's. I would swap but my color don't match and I'd be freaked out about not being able to see out my mirror.
    -Greg
  3. #303
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    Im actually gonna hold on to the mirrors for now. Im thinking if I get a spot mirror it will help the blind spot I have. Sorry to get anyones hopes up but Im having a hard time letting these go lol.
  4. #304
    Even with the mirage glass the adjustment maxes out. For race purposes I would stick to what works best and is safest, which means go back to stock. As for me on the street and for jdm sake I deal with the wide view I get from the jdm mirrors, I got used to it. Its like having that wide view clip-on to the rear view but on the driver side mirror I get to see the blindspot with minimal effort but it appears far away.
  5. #305
    08-26-2007
    1,148
    well heres my update, hopefully I can get it it done before the kids wake up. So I took on a whole bunch of projects this winter and logged about 46 hours so far in the past two months, that's working nights and almost every Saturday. All I have left is to the bleed the brakes, take it to the dyno for a re-fresher in two Saturdays and add some roll bar padding.
    Fabbed up some aluminum door panels
    Was able to keep the controls in the door
    Added mesh to the front bumper opening to keep all the crap out my intercooler
    Riveted and done
    Decided to clean up some wiring and move the important gauges into eye view on top of the dash. Also added some junctions terminals for the gauges to neaten up the wiring. Top one is the switched 12v the middle is power for the lights and bottom is ground.
    Fabbed up and aluminum panel for the gauges and any other future gauges, switches or circuit breakers that need to be panel mounted.
    2" holes cut
    Done
    Harness's finally came
    So I think figured out why I was leaking gear oil from on top of the tranny, at first I thought the selector lever cover was leaking but then I looked real close and thought why is there a small opening on the cover with traces of oil all around.
    Well I was missing the rubber plug, Im gonna feel real stupid if this was the reason.
    Got the Grimmspeed mounted and wired to convert to electronic boost control. Not wired to the AEM yet the tuner is gonna do that on the dyno day so I don't fuck it up lol.
    Lastly my attempt to eliminate or at least soften the torque steer. I stumbled upon a lancer build on evom by chance and this guy swapped an 06 2.4 ralliart motor and tranny into his older base lancer. In his pics he showed the intermediate shaft installed and Im like that 69 block looks identical to my 64 block. I dug around the net for some pics of the back of both blocks and they looked so close that I had to take a chance. I picked up the parts from my local dealer and went for it.
    Test fit went well so I ordered an axle from NAPA.
    I had to chase the threads cause the bolts didn't want to thread in all the way but now there fine.
    Got the axle and installed without a problem. The length seems correct and everything seems fine so far so Im gonna go with it. I did take some measurements before I order the axle and they were the same as on their spec sheet but I was so anxiuous to get it on that I never check the axle measurements once I actually had it my hands. Like I said though its seems to fit fine.
    Its kinda hard taking good pics in that area
    Other things I did were change the brake lines and have the shop I go to change the piston seals in the front calipers.
    Well be headed down to VIR at the end of March for the season opener, I cant wait!
    These pics were from January
    Behind my DD
  6. #306
    Nice work. I'll be looking forward to seeing video of how well it performs this Spring.
  7. #307
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Damn I had seen that the 4g69 lancers had that intermediate shaft but wasn't brave enough to invest the money to find out if it fit, thats great bro car look great, I'm really interested in a review about new axle ;)
    4g64T 5spd
  8. #308
    Going to do that axle mod now. I love the aluminum door panels homie. Car is looking real good. Inspiring me to get mine done
    Jigz-TGCIL Sosick Motorsports
  9. #309
    Great work, love the cage and great choice in harness.
    Any chance you could list he part numbers you used for the axle swap?
  10. #310
    08-26-2007
    1,148
    Sure but I wont be back at the garage for a few days and that's where I got all my notes. For the record I haven't tested it yet let alone put the wheels back on and set on the ground so I cant say its a success yet until I bring it to the dyno next week and let them beat the shit out it. But yea I should be able post everything Tuesday. The other thing is you have to make sure your block has the bosses drilled and tapped otherwise you cant do it.
    When I first got the parts I pulled my spare block to test fit and the bosses where completely blank, I was like fuckkkk!! But then I checked my block in the car and they were drilled and tapped. How lucky was that because the spare block was the one that was actually in the car in my first build but then the thrust washer seized and I had rebuild everything with the current block. I cant tell you how relieved I was. Here some pics of what Im talking about.
    The bosses are marked with yellow paint marker
    So check the back of your block first.
    Parts cost around $250 and the axle from NAPA was $69 with a $55 core. I hope they don't get mad when I send them my old torn driver side axle as acore.
  11. #311
    TGC Regular Guzm4n's Avatar
    02-02-2011
    Des Moines, IA
    736
    The Money Pit!
    Good work, love how much of a track car this has turned into!
  12. #312
    that axle swap! its a must omg, and im loving this build.
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  13. #313
    07-02-2011
    South Florida, by the beach
    1,076
    This thread makes me
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  14. #314
    Yes sir!
  15. #315
    10-24-2003
    1,432
    Why not just drill and tap the block? Good bits measure carefully and use plenty of cutting oil and it should be fine. Keep track of depth as well.
    www.gooichimotorsports.com
  16. #316
    08-26-2007
    1,148
    I guess you can do that but I would probably never attempt it for a few reasons and Ill explain why. You would have to get the holes completely square to get the factory fit, if the holes are crooked it would probably work but not something I would be comfortable with. I would rather a machine shop with the proper tools handle this task and the block would need to be out of the car for that which at that point I would just get the correct block. If the holes are not aligned then your gonna have to hog out the holes on the shaft bracket not a big deal I guess. Your also drilling a 10mm hole into a cast iron block so your gonna have to start with a small pilot bit and keep stepping it up, again its very difficult to get a square hole when drilling by hand and even more when you have to step hole sizes up. Not to mention your working a very tight area and getting a regular hand held drill in there seems impossible, you would need a right angle drill and Im not even sure that fit.
    I know Im pessimistic at times but I cant help it. Im not saying it cant be done Im just saying why I probably wouldn't attempt it. The first thing you have to do is see if a drill actually fits back there.
  17. #317
    This car is a prime example of "because racecar" lol, nice work as usual
  18. #318
    Very impressed with the commitment and work carried out. Would love to track my car but to good a daily for that. Love ur work!
  19. #319
    08-26-2007
    1,148
    Thanks everybody it means a lot.
    So I thought more and more about drilling and tapping the block for the shaft bracket and now I would probably attempt. I would pull the engine and tranny to do it though because honestly I don't think a hand drill would fit back there.
  20. #320
    Yes I'm just going to freehand a couple axle bracket holes in grey cast iron with a corded drill and a squirt bottle of cutting oil. Might as well dremel my heads out while they're on the motor at the same time.
    I love this car, and envy your cage. If you really think you're going to drill and tap cast iron you're either nuts or you have some extremely extremely expensive consumer tools...
