Thread: Rim Question
Showing results 1 to 7 of 7
    Arsenio3
    Icon5 Rim Question
    I have a stock 03 GTZ, and i'm looking to buy some new 18"x8" rims with a +45 offset and 225/40/18 tire. Will my car have the clearance to wear these?
    Member SirSaula's Avatar
    11-20-2010
    Dallas, Texas (Lubbock)
    286
    yep
    9th Generation Mitsubishi G
    TGC Texas Chapter
    Friends don't let friends drive stock. Ever
    Arsenio3
    So no modifications required like rolling fenders or adjusting anything?? i dont plan on lowering my car at all, so i just wanna make sure these will fit before i buy 'em.
    yep itll fit fne, The stock offset I believe is 48 so your only 3 mm out, no modification required
    Arsenio3
    thanks guys
    FYI, stock offset on the US 8G V6 is 46mm.
