Thread: car wont idle when cold !!!
Page 1 of 4 1234 LastLast
Showing results 1 to 20 of 61
    my cousin's 99 wouldnt idle when he starts it in the morning unless he held the gas pedal for few minutes then its fine, i checked the iac and replaced with 2 other working ones and it didnt make a difference, the only other thing i can think of is the TPS but i havent tried to swap it yet.
    any ideas of what else could be causing this problem ??
    thanks for any help in advance.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    i would check for vacuum leaks and it sounds like it could be something fuel related to.
    checked for vacuum leaks intially and found out that the intake manifold was cracked so we got that replaced but it didnt make a difference, we checked for other leaks and none was found
    how would it be fuel related when the car runs smoothly once its warmed up ??
    '95 Kawasaki ZX9R
    what does the car idle at after you give it gas to keep it running?
    I believe it idles normal.
    '95 Kawasaki ZX9R
    when was the battery and alternator last changed on it?
    Lil over a year ago we replaced both of them at the same time.
    '95 Kawasaki ZX9R
    ok when is the last time it had a tune up?
    i know u r trying to help and all man but i am no noob, i own 2 galants and worked on many others and those 2000+ posts arent all off topic
    ive checked the basics so unless u have something that i havent thought off please dont waste my time
    thanks
    '95 Kawasaki ZX9R
    maf sensor?
    maf sensor?
    We tried two other working ones from my own cars and there was no difference.
    Once the car is warmed up, it idles like its supposed to.
    '95 Kawasaki ZX9R
    I have the same prob with my 2003 v6 3.0 . I was sure it was the IAC and am now looking to buy one for cheap. If you changed yours and saw it didnt work, im thinking about saving myslef the $ until you find some solution. They are super expensive.
    cleaning the throttle body didnt do much, MAF wasnt problem on mine either. I do have codes on the car for the O2 sensors... could that be the prob ??
    Quote Originally Posted by lawrd44 View Post
    O2 sensors don't normally cause it to act this way but at least u have codes but we have no codes.
    U can get the IAC on eBay for cheap that's where he bought his for cheap.
    Sent from my HTC HD2
    '95 Kawasaki ZX9R
    The TB must be clogged as hell. Take that sucker out, pull the bottom apart and clean it.
    Its mostly a DSM problem, but even the 8g TBs work on the same principle. The FIAV (choke) is spring loaded temperature sensor that opens when the coolant thats running thru it is cold and it allows more air to flow. It closes when the coolant temps reach certain temp and the engine can sustain its own idle with or w.o the help of the iac.
    ill try that, we have a spare TB so ill clean that out thoroughly and install it and hope it fixes the problem
    is there a way to test the IAC to make sure its operating properly ?? cuz now we have 3 of them and i hate to throw them away if they are working
    '95 Kawasaki ZX9R
    TGC Regular djhah's Avatar
    03-15-2010
    nashville, tn
    505
    is there a way to test the IAC to make sure its operating properly ?? cuz now we have 3 of them and i hate to throw them away if they are working[/QUOTE]
    Are they for the i4 or v6? You could sell them. I have a v6 tb laying in my garage waiting for a iac sensor so i can put it on my g.
    Im in need of a v6 IAC too. If they work and the price is right ill be happy to take it.
    Yes! The O2 sensor can totally do it depending on how cold the engine reads out. With a bad O2 sensor the car is pushing more gas then it actually needs when cold. So by reving it up you are by passing the O2 from an idle position to a running position. And heating up the O2 at the same time. Its long to explain. Lond story short the mix is to rich due to a bad O2 causeing the motor to stall at idle when cold.
    The IACs that we have are for the I4
    '95 Kawasaki ZX9R
    If you think it might be the IAC then check this out. You may be able to clean out your original one.
    http://www.youtube.com/watch?v=6TZK_RqjjD8
    Also I havent tried swapping a I4 IAC to a V6 but I know I wouldnt try due to them being different maybe.
    Still replace the O2 sensor. But when you do buy a new one from the dealer. Do not buy Bosch replacement. I have only heard bad things with people doing that.
