Thread: car wont idle when cold !!!
Showing results 41 to 60 of 61
  1. #41
    Please tell me u r joking.
    Our cars have 2, a temperature sender which sends the signal to the gauge and so u can see your temp and that one is located on top of the thermostat housing and has one wire
    The temp sensor is located under the thermostat housing and screws into the head and has two wires and that has nothing to do with the gauge.
    If u believe I'm wrong please prove it but from what u said I bet u didn't know that we had two on our cars.
    Sent from my HTC HD2
    The one you changed was the brass one that sends the signal to the gauge or the other one?
    When the car is starting cold, does it sputter, or just rev and die? Since you say that it gets back to normal when the engine warms up, it sounds like has to do something with the oil/coolant reaching the optimum temperature right? Did you try giving it some gas when you start it and see if it triggers the CEL? I know this might sound obvious, but did you read the codes with the scanner even without the CEL coming on, there might be some stored?
  2. #42
    08-13-2008
    Waterbury, CT
    3,331
    i read the whole thread and see nothing about the FIAV being touched. find another throttle body and swap the FIAV over or just put in the whole throttle body as from what i see in the diagrams the FIAV is built into the throttle body and isnt a seperate part like on the dsm throttle bodies.
    my car did this to me 2 years ago and it was the FIAV
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  3. #43
    If I remember from some of the Realfixes Real Fast videos on youtube, there was one about an intermittent issue that only happened when the engine was cold, it was a loose wire. When the engine got warm, the heat expansion caused the wire to hold contact.
    I'd also be interested in a compression check when the car is cold. Again heat expands things so gaps can close up (also related to gaskets, and such)
    I've also had cars before that had weak batteries that were fairly new that required some revving to store enough current to keep the system going.
    Get the engine cold again and jump it from another car and leave it connected and see if it stalls.
  4. #44
    what does the FIAV do ??
    u and mko said the same thing and since both of you suggested the same thing and i have 2 G's running 100% i am gonna take the TB along with the IAC and TPS and install it on his car and see if that fixes the problem
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  5. #45
    08-13-2008
    Waterbury, CT
    3,331
    THe FIAV has wax inside...when its cold the wax is hard and lets more air through hence higher idle ( to warm up quicker ) on cold starts. Then when the coolant running through the TB and the engine temps get higher, the wax melts and stops air from going through, thus allowing the car to idle lower at normal operating temp ( 700-900 ).
    it could have went bad or something. i would try another throttle body and see what happens
    2014 Lancer Evo GSR
  6. #46
    Where is that located ?? I'm curious cuz I would like to see what it looks like.
    '95 Kawasaki ZX9R
  7. #47
    08-13-2008
    Waterbury, CT
    3,331
    its on the bottom of the throttle body. it is why the coolant lines are going to the throttle body. i believe it is all one piece and you cant take it off as from the diagrams i have looked at only the IAC is a seperate unit
    2014 Lancer Evo GSR
  8. #48
    i know it cant be taken off since i had an extra TB and as to chris's first suggestion i was gonna clean it but couldnt find it, i just wanted to know where it was located and ur answer is the same thing chris's told me over the phone
    '95 Kawasaki ZX9R
  9. #49
    08-13-2008
    Waterbury, CT
    3,331
    its the bottom of the throttle body. i dont know how to clean it on yours as it cant come off like on our throttle boddies. if switching the TBs over works and you are using the same TPS then i think its safe to say the FIAV is bad.
    2014 Lancer Evo GSR
  10. #50
    we shall find out soon
    '95 Kawasaki ZX9R
  11. #51
    swapped my TB from my car and it worked, tomorrow we r heading to the junk yard and gonna try to find another TB for him
    '95 Kawasaki ZX9R
  12. #52
    08-13-2008
    Waterbury, CT
    3,331
    good to hear. good luck finding another one
    2014 Lancer Evo GSR
  13. #53
    A local u pull it had two it three when I was there two months ago.
    '95 Kawasaki ZX9R
  14. #54
    got a TB from the junk yard, started the car and ran great, hit the gas pedal and then shit went back to where it was before
    i dont get it
    '95 Kawasaki ZX9R
  15. #55
    i dont get it
    did you try putting another iac in it the one thats in it could be bad from sitting at the junk yard
  16. #56
    Of course common sense that I tested before I even installed the TB
    '95 Kawasaki ZX9R
  17. #57
    what about the fuel filter did you try changing that?you can also try putting some fuel system cleaner in it see if that helps maybe something is clogged.
  18. #58
    i hate to see fix your your car, cuz u sure will waste way more money than necessary
    fuel filter wont cause those symptoms, do u even relate the symptoms to your suggestions ??
    '95 Kawasaki ZX9R
  19. #59
    08-13-2008
    Waterbury, CT
    3,331
    So what you are saying is you put your throttle body on his car and it worked but once you put in the jy throttle body it's back to where it was?
    2014 Lancer Evo GSR
  20. #60
    Have you checked the PCV valve? I've had these symptoms when the PCV valve was bad, because after the car warmed up, the inner valve did move easier than when it was cold.
