For the wiring, use an harness adapter, so you wont have to cut any factory plug, and they already come labeled and coded; to access the black boot for the doors, take out the kick panels, passing the new wiring is not an easy task, so be patience; if you can also take out the lower part of the dash, Ill help to get a better access.
