Thread: Tick...Tick...Tick...Tick....
Showing results 1 to 10 of 10
    San Antonio, Tex-Mex
    1,413
    Yes, it sounds like a bomb!
    There is a loud ticking noise coming from behind the dash on the passenger side. It is in constant increments much like the ticking of the turn signal. It is sooo LOUD!!
    I managed to troubleshoot enough to find that it goes away when I push in the button for recycled air. When I turn the recycled air off, it starts ticking even if the fans are not on.
    This is the wierdest and by far the most annoying thing that has ever happened with my car... any ideas?
    Wes
    <-Check it out Maz
    My 7g
    sleepagalant
    i have the same problem
    thought i was the only one
    i have no clue what it is though... too poor now to find out
    IllestGalant
    the motor for the fresh air door or the fresh air door itself may be binding.
    remove the lower panel on the pass side and shine a flashlight up and feel around, can you feel the tick?
    yes, it IS the "fresh air/recirc" motor.
    very common failure on these cars. Just go buy a new one, remove the glove box, and BAM! there it is. Its held in place with 3 screws.
    piece of cake to replace if you have any mechanical knowledge whatsoever.
    1,413
    Great, I was hoping it would be simple. I will order one this week.
    Thanks guys :thumbsup:
    <-Check it out Maz
    My 7g
    PurpleHaze
    I've got this problem now on my 8g, but it's not from the passenger side, it's sounds like it's coming from the center vent by the windshield. Is this the same kind of part that i need? It only does it when the temp knob is all the way on the left, but I would still like to fix it
    i had the same noise some time ago and realized that it was the alarm making the noise.. cause of my battery was dead/dying
    PurpleHaze
    Thanks for the tip, I just don't think it would be that because it only does it when my temperature knob is all the way to the left on cold, otherwise no noise
    Experienced TGC Member Bezzle's Avatar
    11-12-2005
    Paterson TGCNJ
    1,940
    conduct ye searching and thou shall prosper...
    https://www.thegalantcenter.org/viewt...pic.php?t=44917
    still gotta fix mine btw.
    PurpleHaze
    thanks man. that noise is f'in annoying and it's starting to get warm out so i need my ac
